I would to use the QNAP HBS 3 (Hybrid Backup Sync) application to backup my data on Amazon S3 (new Europe region - Milan).
When I schedule the target folder to backup data on the bucket, the system returns a network error trying to list the bucket's folders.
Below, the QNAP HBS 3 Hybrid Backup Sync log entry:
504 GATEWAY TIMEOUT {'error': {'error_code': 'cloud_network_error', 'message': "HTTPSConnectionPool(host='s3-eu-south-1.amazonaws.com', port=443): Max retries exceeded with url: /bucketname?list-type=2&delimiter=%2F&max-keys=1000&encoding-type=url (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6bd01110>: Failed to establish a new connection: [Errno -2] Name or service not known'))"}}
The s3-eu-south-1.amazonaws.com endpoint seems to be not reachable.
So, I contacted Amazon Technical Support that answered me "The s3-<region> endpoint format (with a hyphen instead of a period between "s3" and the region name) is a legacy format that is not supported for newer regions.
https://docs.aws.amazon.com/general/latest/gr/s3.html
https://docs.aws.amazon.com/AmazonS3/la ... sting.html"
The only address reachable is s3.eu-south-1.amazonaws.com.
Is there any way to force the endpoint address in HBS 3?
Thank you for your support.
Best regards
Alberto
HBS 3 backup on Amazon S3 (new Europe region - Milan) doesn't work
Re: HBS 3 backup on Amazon S3 (new Europe region - Milan) doesn't work
I don't know as I'm not a S3 user. Please ask Qnap support.
Thanks for your reply.
I've already written to the QNAP support (about 20 days ago) and they answered that unfortunately, there's none for new regions. However, they will inform their product managers about this request in order to consider this in future release.
In the meantime, I'm not able to backup my data to the Amazon S3 using the HBS3 utility. So, I would like to know if someone used a workaround for the issue.
I think that it's a recurrent issue for users that store data to new Amazon regions like mine (Europe - Milan).
Best regards
Alberto
Best regards
Alberto
Re: HBS 3 backup on Amazon Cape Town region
Same problem - can not use the new local Africa (CapeTown): af-south-1 region
