S3 Plus stopped working, all backups lost?
dbblac100
First post
Post by dbblac100 »
I have used S3 Plus for several years now always doing my backups perfectly.
After the last firmware upgrade of my TS-251 to the version 4.5.1.1456 the program is no longer available
The simple error message:
[App Center] S3 Plus has an invalid digital signature. The app has stopped and cannot be installed on QTS. You can remove it in the App Center.
Any idea how to restore my data? I have used the data encryption function from the program, without it I can no longer decrypt my backups.
BRgds,
Dirk
dolbyman
Re: S3 Plus stopped working, all backups lost?
Post by dolbyman »
lot's of threads open about the digital signature issue
open a ticket with QNAP to complain
downgrade the firmware to regain access to the program again in the meantime
szielke
First post
Post by szielke »
Got the same issue with different apps. You can login via SSH and start the app manually. Anyways, it appears that they have a scheduled scan running every day which disables the apps again. But most important: your data is still safe. Let´s hope for a soon update
Return to “Amazon S3”
