I am using HBS 3 to backup to S3. I also use simple versioning to keep 3 versions.
I ran this scenario #1:
1. Create backup job that keeps 3 versions, and with client side encryption
2. run backup job
3. modify files
4. run backup job again
5. create restore job based on the backup job
6. I can restore any version
7. I can restore to original location
but in this scenario #2:
2. run backup job
3. modify files
5. delete backup job
6. create restore job based on the backup job
7. I can only restore the latest version
8. I cannot restore to original location.
It seems that versioning works in scenario #1 as expected, but in #2, I cannot restore the version I want. How can I restore any version I want in scenario #2?
Also, how can I restore to the original location instead of creating a new folder and messup the structure?
UPDATE: looks like the versioning works in #2 if I restore the metadata first, and then restore the backup. Still not sure about restoration location.
HBS 3 Restoring from Versioned Backup in S3
Re: HBS 3 Restoring from Versioned Backup in S3
did you get any smarter on this?
Another question: How can I restore the data in a specified folder (not in the folder "latest", but further up in the directory)?
Best,
m.
Best,
m.
