WebDAV backup to 1&1 webhoster not working (windows works)
QNexus
Post by QNexus »
I have just installed the QNAP WebDAV CloudBackup Station app (V 1.1.330) and tried to backup a very small folder to German web-hoster 1&1, who supports WebDAV. (A Windows 7 WebDAV connection to this webhoster/my domain - using the same credentials (with BasicAuthLevel=2) - works perfectly fine).
Anybody having a similar challenge - or even a solution?
Here is what the QNAP Debug file says [I just replaced actual domain name with "my1und1domain"]:
2015-02-28 16:37:42,075 PID:5997 utils.py:538 cc INFO start a backup job: 1
2015-02-28 16:37:42,795 PID:27441 engine.py:1013 cc INFO begin backup job:1
2015-02-28 16:37:43,788 PID:27441 engine.py:576 cc INFO Concurrent connections number: 3
2015-02-28 16:37:44,176 PID:27441 backupscannerworkerthread.py:645 cc INFO 21zu9->qnap change sub_state to Scanning
2015-02-28 16:37:44,177 PID:27441 engine.py:609 cc INFO 21zu9->qnap, Go!
2015-02-28 16:37:44,179 PID:27441 backupscannerworkerthread.py:648 cc INFO 21zu9->qnap Scaning local files
2015-02-28 16:37:44,187 PID:27441 diskdataprocessor.py:146 cc INFO scan source: ['/Multimedia/Photos/21zu9'], ignore symbolic link= False
2015-02-28 16:37:44,205 PID:27441 backupscannerworkerthread.py:655 cc INFO 21zu9->qnap change sub_state to Uploading
2015-02-28 16:37:44,674 PID:27441 backupscannerworkerthread.py:669 cc INFO 21zu9->qnap Uploading files
2015-02-28 16:37:44,951 PID:27441 webdavconnector.py:640 cc ERROR create remote folder fail: QNAP/CloudBackup/qnap3/Multimedia/Photos/21zu9
Traceback (most recent call last):
  File "./package/src/shared/bin/connector/webdavconnector.py", line 633, in _test_and_create_folder
  File "./package/src/shared/python-lib/easywebdav/client.py", line 309, in mkdirs
OperationFailed: Failed to create directory "QNAP".
  URL           :  http://webdav.my1und1domain.org:81/QNAP
  Operation     :  MKCOL QNAP
  Expected code :  201 Created, 301 Moved Permanently, 403 Forbidden, 405 Method Not Allowed
  Actual code   :  500 Internal Server Error
2015-02-28 16:37:44,957 PID:27441 connectorworkerthread.py:697 cc ERROR re-raise exception
  File "./package/src/shared/bin/workerthread/connectorworkerthread.py", line 655, in __process_upload_task
  File "./package/src/shared/bin/workerthread/connectorworkerthread.py", line 593, in __do_upload
WebDAVConnectorCreateFolderError: (WebDAVConnectorCreateFolderError(...), -2201, 'the job failed to create folder(s) on the cloud storage. Please make sure the cloud storage service is within the compatible list')
honigapfel2
Re: WebDAV backup to 1&1 webhoster not working (windows work
Post by honigapfel2 »
I've been using this link
https://sd2dav.1und1.de
And the backup works.
For me, the recovery from the cloud does not work.
You must use the version 1.0.350.
This works perfectly for me.
Return to “WebDAV-based Backup”
