Hallo,
since the upgrade of the CloudBackup station to Version 1.1.379 on QTS 4.2.0
the WebDAV backup is not able to create a new folders on MagentaCloud.de
What I tried:
The WebDAV access on Windows works fine and I can create folders and copy files.
I have created a new account and backup job. Still job does not copy any file and created any folder even so the initial test passed.
Before the upgrade it worked fine the last 3 month.
Does anyone has the same issue?
Thanks!!
Full error message:
Error: cannot upload file *** because the job failed to create folder(s) on the cloud storage. Please make sure the cloud storage service is within the compatible list.
I have found the this post http://forum.qnap.com/viewtopic.php?t=104093.
In my case it worked fine before.
Issue with 1.1.379 - job failed to create folder
TS 251, 8 GB, two WD30 reds, static single volume, single port
- sbimdesign
Re: Issue with 1.1.379 - job failed to create folder
Same issue here
best regards
Siggi
BALDAUF PRODUKTDESIGN - german industrial design
TS-890 Pro 4x 2GB WD RED 4x 1GB WD RED
TS-469 Pro 4x 2GB WD RED
Siggi
Try the new Hybrid Backup Sync - Beta App. Solved the Problem for me (though not with MagentaCloud but my own Apache Server).
