i use Hybrid Backup Sync Cloud Backup, backup target is a owncloud webdav. http works very well but https does not work ...
the ssl certificate is correct ... all other apps works very well over https (owncloud app, win7 webdav mount, WebInterface via Firefox is trusted) ... the ssl certificate is not self-created ...
[2016-09-01 08:04:09,591][JOB:ENGINE][PID:31069][TNAME:MainThread][ERROR ][cc][webdavconnector.py:test_account:456] : test account fail
Traceback (most recent call last):
File "./package/src/shared/python-lib/connector/webdavconnector.py", line 453, in test_account
File "./package/src/shared/python-lib/easywebdav/client.py", line 414, in ls
File "./package/src/shared/python-lib/easywebdav/client.py", line 403, in _ls
File "./package/src/shared/python-lib/easywebdav/client.py", line 251, in _send
File "./package/src/shared/python-lib/easywebdav/client.py", line 204, in _request
OperationFailed: Failed to list directory "".
URL : https://XYZ.org:443/owncloud/remote.php/webdav/
Operation : PROPFIND
Expected code : 207 UNKNOWN, 301 Moved Permanently
Actual code : 408 Request Timeout
[2016-09-01 08:04:09,594][JOB:ENGINE][PID:31069][TNAME:MainThread][ERROR ][qnap.cgi.base][base.py:do_command:363] : (ConnectorAuthenticationError(...), -2002, 'of cloud storage authentication error. Please check your account settings')
File "./package/src/shared/python-lib/qnap/cgi/base.py", line 357, in do_command
File "./package/src/shared/python-lib/qnap/cgi/commandmgr.py", line 1219, in cmd_test_account
File "./package/src/shared/python-lib/connector/webdavconnector.py", line 457, in test_account
ConnectorAuthenticationError: (ConnectorAuthenticationError(...), -2002, 'of cloud storage authentication error. Please check your account settings')
QNAP TS_853A
Version 4.2.1 (2016/06/01)
Hybrid Backup Sync Version 1.0.160707
Sorry for my bad english, i hope anybody can help
Hybrid Backup Sync - WebDav does not support HTTPS
Re: Hybrid Backup Sync - WebDav does not support HTTPS
I'm afraid I can't help but I can confirm that HTTPS Webdav does not work, not with 4.2.1 and also not with 4.2.3 and the latest Hybrid backup sync and Cloud Backup sync.
@QNAP: please fix the HTTPS Webdav, it's useless with HTTP only.
Confirmed issue with WebDAV/SLL(IIS) with both Hybrid backup and WebDav QPKGs.
Hope will be fixed soon.
