Hybrid Backup Sync 1.2.161226
This HBS version does not allow WebDAV as cloud, because it does not exist in the cloud list.
Steps to confirm:
Setup your WebDAV cloud and run the test, after that a QNAP folder should exist in the root folder.
Go to the HBS overview page, press Sync+ below the 'create job' window
Select bi-directional upper right and cloud in the next window
Be wondered, your WebDAV is missing in the list of available proprietary clouds.
Click storage in left panel, click 'Cloud' on the right side, here is your WebDAV cloud listed.
Creating a job for the WebDAV cloud impossible.
Hybrid Backup Sync: WebDAV is not a cloud?
- Linuxfarmer
TS-231P - 4.3.3 / 4TB Seagate Ironwolf (Drives RAID-1)
- Linuxfarmer
Re: Hybrid Backup Sync: WebDAV is not a cloud?
Update: QTS is 4.3.3 now. HBS has 2.1.170410
My webdav cloud is now listed under Storage Cloud:WebDav. At HBS start screen the 3 folder on the harddisk are listed and below my Cloud at WebDE
Please do this to experience the bug:
- Create a WebDAV cloud account profile including test sync run in HBS.
- Press Sync button to create a new sync job. Choose bidirectional or whatever you like, select the cloud logo on the right
Here the configured WebDAV cloud is missing completely. When will we see a HBS release without this bug?
Linuxfarmer
Linuxfarmer
I was missing this too! I migrated from a Synology NAS where I used Cloud Sync to synchronize bidirectional using WebDAV (STACK TransIP). I clicked on Sync using cloud, but WebDAV was not there?! What's going on QNAP?
- Linuxfarmer
Soon we will have a birthday party with this, cookies.......
QTS is 4.3.4 now
HBS is 2.1.18207 now
....and WebDAV is not a cloud like before. Well done.
QTS is 4.3.4 now
