I have tried to connect to my own cloud which is formed through a NextCloud 12.0.4 Installation (tried also 12.0.1 previously) using Hybrid Backup Sync/Cloud Backup Sync but it tells me the authentication failed - the connection details are definitely right and I tried HTTPS as well as HTTP.
Any hints how I can troubleshoot the QNAP side?
Cloud Backup Sync connection to NextCloud using Webdav is not working
Re: Cloud Backup Sync connection to NextCloud using Webdav is not working
Did you ever get this working? I'm having the same problem trying to connect to a NextCloud server.
TVS-473
32GB Ram
FW 4.3.1
32GB Ram
FW 4.3.1
Hey, I'm having also the same problem, I'm trying to remote mount a nextcloud webdav into my QNA NAS (TS-653A) and it always throws the error:
"System message
Failed to connect to remote server. Please check your connection settings and try again."
I'm very certain that the connection data is correct and I'm also getting a ping on the nextcloud host. Any pointers?
Best regards, M
"System message
Best regards, M
Have you tried the URI WebDAV?
This is the URI that worked for me:
https://<my-server>/remote.php/webdav/
- OneCD
