Webdav and stack (TransIP)
rvamerongen
Getting the hang of things
Post by rvamerongen »
If I fill in the webdav server that stack ( https://www.transip.nl/stack/) provide like ( of course with my own discname, username and password) :
or
or
the server field turns directly red. What went wrong?
What should I fill in in that server field? Any suggestions
if i create this in the Hybride backup > Webdav I get the message that the connection failed. But every server name is failing, even connecting to my local WB-cloudmirror webdav server.
Thank you
QNAP TS-453A - 4GB-RAM - 16TB - QTS 4.3.4 - RAID 10
rvamerongen
Re: Webdav and stack (TransIP)
Nobody is using stack? Or can help me? Is there a QNAP tutorial about webdav?
dolbyman
Post by dolbyman »
here is a webdav tutorial ... no idea if it helps (it's the other way around .. reaching the NAS via webdav, not reaching webdav services from the NAS)
https://www.qnap.com/en/how-to/tutorial ... via-webdav
Ynnoz
Post by Ynnoz »
Have a look at the Dutch website: http://www.tweakers.net. They have a forum and a special board dedicated to Stack.
musicfreak
Post by musicfreak »
I know this is a Old one but i wanted to respond to it with a answer.
i think there was some error with Stack and the webdav connection that is Solved some time ago.
To get the correct webdav link you first login to your transip Stack webdav. like to https://name.stackstorage.com ( or if you use a own domain use that)
When you go to your setting page you see Webdav there and it will show you a like like https://name.stackstorage.com/remote.php/webdav/
use that as the adres and the name and password you set and it works.
Fsaad1984
Post by Fsaad1984 »
Anyone having a solution for thes constant connection errors?
I tried using both, a Token and my normal account's password (without special characters), neither without failing results.
Enabling or disabling Version Management or QuDedup doesn't change a thing either.
Data is being copied though. Sometimes a few KB's, sometimes a few GB's, but it always ends up with "Failed to connect to cloud storage server after multiple attempts. Check network settings"
QNAP TS-673
Fsaad1984
Post by Fsaad1984 »
BUMP anyone?
QNAP TS-673
rvamerongen
Stil having problems. I keep it running to keep my account active, in the hope of......
Fsaad1984
Post by Fsaad1984 »
rvamerongen wrote: Sat Mar 21, 2020 5:01 am Stil having problems. I keep it running to keep my account active, in the hope of......
I am using Duplicati for the time being, no errors during backups, but as it is not a native QNAP app, the notifications are less convenient.
QNAP TS-673
jol4@
Post by jol4@ »
Exactly the same errors "Failed to connect to cloud storage server after multiple attempts. Check network settings" for several months now since firmware 4.4.1 all versions (latest 1216) and latest HBS3 3.0.200212
Fsaad1984
Post by Fsaad1984 »
Did anyone try the paid version of STACK?
QNAP TS-673
rvamerongen
They told me, it has the same setup.
rvamerongen
About Duplicati, I saw it before, but don't know what version I should download for a TS212 or a TS-453A.
https://qnapclub.eu/nl/qpkg/369#
Or are there somewhere more packages?
Fsaad1984
Post by Fsaad1984 »
I run Duplicati as a Docker container.
https://hub.docker.com/r/linuxserver/duplicati/
QNAP TS-673
hvdrunen
Post by hvdrunen »
Same problem for me on TS-453a
Return to “WebDAV-based Backup”
