Hello all;
I have 2 TS-859U NAS and they're running solid; I'm at a point where I need to start archiving monthly comppletes to the cloud. We bought a 1 year unlimited plan from OpenDrive and for the most part it's ok for now.
I'm trying to use QNAPs apps to accomplish but cannot make headway. Has anyone else used a QNAP with OpenDrive?
Tryying to use webdav, might be able to use ftp. Thanks!
Unable to copy files to cloud using QNAP apps
Re: Unable to copy files to cloud using QNAP apps
There is no specific OpenDrive support in the Hybrid Backup Sync app but there is a WebDav option...
