Which File is Infected?
rlanza1054
Post by rlanza1054 »
I'm pretty new to Qnap but I keep running into issues.
Ok here is my latest issue:
I also had McAfee say I had two infected files. I don't see anything listed in the quarantine area.
I downloaded the mcafee report file and opened it up to file thousands of entries saying 'not scanned (err:11)'. Since there are thousands of entries I figured I would simply search for the err number of the infected file.
Well I have searched for an hour on how to read a McAfee log file to see how McAfee write the info so I can do a search.
Nothing!
So would someone please tell me first what the err number is that i can search on.
Second is the a tool that helps you analyze these log files for easy reading.
Third, why am I getting thousands of entries saying 'not scanned (err:11)'
Forth, why is McAfee using up all my CPU.
In the resource monitor it's stating that McAfee is using 56% of CPU recourses. And since I occasionally run a Full Scan and I keep the Real Time Scanning turned on my Qnap NAS CPU is always pinned at 98% usage.
Is this product worth having?
The built-in anti-virus seems to run just fine and actual caught something once and actually move it into the quarantine area.
Thanks for any help!
Rob
OneCD
Re: Which File is Infected?
Post by OneCD »
* topic split from viewtopic.php?f=329&t=153394 *
Return to “McAfee Antivirus”
