Hello.
The last six backup jobs from my NAS to Google cloud storage have failed after 5 minutes of run time each. The error is "Backup job [job name] is abnormally shutdown. Please try again."
I have updated to the latest app release but the error still occurs. I have also restarted the NAS. The backup job had run successfully over 120 times prior to the 2nd September. Any suggestions?
I have attached the google cloud storage app debug log in a .zip file.
TS-451, v4.1.4 (2015/8/20), single port. Google Cloud Storage app version 1.1.364 (2015/7/20).
Thank you.
Arn.
Backup job is abnormally shutdown
Re: Backup job is abnormally shutdown
Check your debug logs or post them (if you're sure there's nothing private within).
You can download the debug log by pressing the button on the top-right corner of the App.
- pwilson
When you're asking a question, please include the followingcraigarnoldt wrote:Hello.
Thank you.
Arn.
Patrick M. Wilson
Victoria, BC Canada
Hi.
I have added additional details about the NAS and attached the Google Cloud app debug logs.
Thank you for your assistance.
You might want to be careful with those debug logs. You definitely want to pull them down from the public access.craigarnoldt wrote:Hi.
There are a large number of errors starting at 09-02:
You better check why the account is disabled. I'm 90% confident that will solve your problem.2015-09-02 21:00:07,801 PID:15361 googlecloudstorageconnector.py:863 cc DEBUG <HttpError 403 when requesting xxxxxxxx returned "The account for bucket "cpgnas1" has been disabled.">"
Which file do I have to check in the debug.zip to get more information about the reason of that abnormally shutdown?
I got almost the same problem after upgrading to:
- 1.0.394 (2016/01/08) Cloud Drive Sync and
- Firmware 4.2.0 (2016/01/01)
I got a TS-210.
Thanks Marc
I got a TS-210.
Thanks Marc
I just updated to Firmware 4.2.0 (2016/01/19). I hope it will getting better.
Hi _icke_,
Did the upgrade solve the problem?
This problem makes the whole google cloud backup of my QNAP unusable.
Thanks for your reply.
I got a TS-412
I got a TS-412
No! I just updated to the actual public beta 4.2.1 but...
since the update to build 0119 (inkl. build 0130 an the new public beta 4.2.1) the sync-job needs much more time for scanning. before the update it needs 3-4 hours to switsch in status from "scanning and syncronizing" to "syncronizing" now the job fails after 2 day in status "scanning and syncronizing" with the same abnormally shutdown.
with the new version: 1.0.419 (2016/03/18) it runs pretty well.
Changelog:
Changelog:
Fixed authentication problem for Google Drive
