[SOLVED] Client sided Encryption
schlimmer121212
Post by schlimmer121212 »
i want to backup my files on google cloud storage. While configuring the backup-job, the wizard asks me, if i want to encrypt my files.
If yes, i have to choose a password as shown in the attached image.
My problem is: After typing in my password, the "OK-Button" isn't clickable. I'm only allowed to cancel.
The password and its confirmation are the same! I also tried different passwords.
Any suggestions?
Last edited by schlimmer121212 on Mon Jun 20, 2016 10:17 pm, edited 1 time in total.
schlimmer121212
Re: Client sided Encryption
Problem solved:
I had to set the system language to english. After that, there was an additional Button to click.
Now you can click "I understand" and after that, the OK-Button is clickable.
Return to “Google Cloud Storage”
