Hi all,
I have purchased a new TS-251+ since my TS-210 was getting a bit old.
On my TS-210 I was successfully running a Google Cloud Storage (GCS) backup. As my TS-251+ contains now a copy of the old NAS, I want to continue with the same backup job on GCS.
However, when trying to set up a GCS job, I get an error message that the bucket is not empty.
From what I have found out so far, this seems to be a general problem with QNAP's Google Cloud Storage app. How can I work around this?
Under no circumstances I want to create a new bucket again and re-upload everything again!
In fact, it would be perfect for me if I could use the rsync option of Google's gsutil command line tool. However, I am struggling to find a way of installing it on the TS-251+. I can't seem to find an app prepared with this tool and installing it like on a normal Linux machine does not seem to be possible due to various reasons.
Any suggestions?
Backup to non-empty Google Cloud Storage bucket / install gsutil
Re: Backup to non-empty Google Cloud Storage bucket / install gsutil
I'm in the same boat - I want a Google Cloud backup to back up, and I have an existing backup storage already in Google Cloud, with all the files present.
However, the QNAP app doesn't seem to check if the files are already there before merrily transferring the file again and overwriting the files already stored - it seems to only consult a local database of what it thinks has already been sent. So now it wants to push out 2TB of data again, after I spent 2 days with gsutils setting up the Google storage so that nothing needed to be transferred on the initial run!
AFAIK, there isn't a workaround, and the only way to fix it is to report this failure to check the cloud storage container before sending the file as a bug or undesirable behaviour, and see if QNAP will fix the app in a future release.
- Moogle Stiltzkin
refer to faq link to create support ticket. expect reply from them in 24 hour :} then they'll know to fix or improve this app.
NAS
Network
Resources
Network
Resources
Hi Everyone,
Apologies for resurrecting this old thread, but I have the same issue and it appears there is no solution yet.
During testing, I was able to create a backup job by creating a new folder within the same bucket. I created a ticket for this issue, and QNAP support have responded that there is a limitation when using Google Cloud Storage and cant reuse a non-empty folder.
I have asked to clarification on whether this is a limitation at Google or the QNAP end, will post an update when I get a response.
Has anyone else managed to find a solution?
TS-453 Pro
Single Gigabit Connection to the network
4 x 3TB WD RED in RAID 6
Hello every one!
Now it is my turn to ask forgiveness for the recycling of an old thread.
Like all those who wrote here before me, I have a problem with the installation process of gsutil on my QNAP.
In my particular case, my aim is seting up the FUSE protocol which allows mapping a directory on the NAS as to a cloud bucket and emulating a file system. I assume that by achieving this goals, should allow me enjoying the option of creating back jobs supporting file versioning managed by the NAS itself, trough the built-in backup apps. A functionality, available only while the backup storage target of a jobs, is a local folder.
If anyone has solved it or have some experience utilizing the Container Startion app, together with a container implementing FUSE, his help would be greatfully appreciated!
