Google Cloud Storage Restore not working
awl123123123
First post
Post by awl123123123 » Fri Sep 20, 2019 11:58 am
I've made a back up of my files using the QNAP Google Cloud Storage App with Client Side Encryption. I tested restoring this before formating my volumes and it worked fine. I've since formated my volumes and when I try to restore my files I get the following error:
[GoogleCloudStorage] Restore job failed because of failing to access local metadata. Please check your disk status (space and inode) and try again.
When I try to back up just the data itself without the meta data, only a handful of files are transffered and then it just stops responding.
Any help on resolving this would be greatly appreciated!
Return to “Google Cloud Storage”
