Hi there
I not sure if Wake on Lan will do what I need (the manual isn't much help) and I have seen other posts in the forum but none 100% explains how it works/whether it will do what I want it to.
Here is what I would LIKE to do:
1) schedule the NAS to go in to some kind of low power/sleep overnight
2) have the NAS wake as soon as any of the connected PCs on the network are switched on in the morning
I have an old Buffalo NAS which does this, but I can't seem to get my Qnap to do the same. Here is what I am trying
1) I have set the NAS to sleep or shutdown at 1am (this works fine)
2) I have set the NAS to wake-on-LAN, but when I switch on a PC, I simply get a message from Qfinder saying it can't find any Qnaps on the network (ie nothing is "woken" - except the Buffalo drive, which wakes just fine)
So my question is - should this work, or is sleep/shutdown not the correct thing to do?
FYI when I "shutdown" the NAS it no longer shows on the network switch (no green light) - but when on "sleep" there is a green light on the network switch (but the orange LAN light on the NAS is NOT lit)
Here is key info/settings
TS-253A
Connected to ethernet network with 2 x Win 10 PCs
QTS v 4.2.2
Power settings:
EuP mode - disabled
Wake on Lan - enabled
Power recovery: Resume server to previous status
Power schedule > Enable schedule (tick) >> Sleep Daily @ 1am
Look forward to any help, thanks!
Understanding "Wake on LAN"
Re: Understanding "Wake on LAN"
to wake the unit by WOL, you have to send a "magic packet" to it, those are broadcast packages addressed to the MAC of the device
https://en.wikipedia.org/wiki/Wake-on-LAN#Magic_packet
- razormoon
- Easy as a breeze
Your NAS will not 'wake' by simply trying to access it. I'm guessing that your old Buffalo had some form of agent installed on your client that sent the magic packet.Jaspos wrote:Hi there
TS-253A
QTS v 4.2.2
Power settings:
EuP mode - disabled
You can add an extra item in power schedule to power the NAS on in the morning or you can install one of many wake on lan apps as some have features on how/when they wake your device.
Thanks to both for the swift reply.
I was aware of the phrase "magic packet" - but as my old Buffalo drive used to wake when I started my PC I had assumed (it appears erroneously!) that my PC was automatically sending this magic packet on start-up.
Are you able to provide any guidance on any wake-on-lan apps (a quick google search provides few options, plus some scripts if I can find the time to investigate) but any recommendations of any apps/code working with Qnap would be most welcome.
Thanks again!
Thanks again!
maybe the old NAS did not actually shut off , but went into standby
So when the windows computer accesses shares on startup, the drives would spin up
It's not rocket science but will take some work to setup an automatic wakeup. You could configure a script to send a Wake-on-LAN (WoL) magic packet to the NAS on PC startup.Jaspos wrote:2) have the NAS wake as soon as any of the connected PCs on the network are switched on in the morning
You have WoL in Qfinder Pro under the Tools menu.2) I have set the NAS to wake-on-LAN, but when I switch on a PC, I simply get a message from Qfinder saying it can't find any Qnaps on the network (ie nothing is "woken" - except the Buffalo drive, which wakes just fine)
Under the menu QFinder Pro, Settings you could also configure a wake-up by double-clicking on the NAS entry.
No the LAN LED on the front of the unit shouldn't be lit but the small LED on the back by the connected network port and the light on the switch should be also when it's shutdown if you have WoL enabled in the Power settings as you do. At least I know it works that way on a TS-853A so it's very surprising that a TS-253A is different.FYI when I "shutdown" the NAS it no longer shows on the network switch (no green light) - but when on "sleep" there is a green light on the network switch (but the orange LAN light on the NAS is NOT lit)
Apologies to all for the slow response. But following all the help I wrote a quick batch script that sends a WOL magic-packet via Powershell. In have set this to run after PC log-on, and now all works as needed.
Thanks to all!
Thanks to all!
Jaspos, pls let us know the scrip you are using in the Powershell, to turn it on and also to turn it into sleep mode. Thx in advance!Jaspos wrote:Apologies to all for the slow response. But following all the help I wrote a quick batch script that sends a WOL magic-packet via Powershell. In have set this to run after PC log-on, and now all works as needed.
Thanks to all!
Ok, here's the Powershell script saved as a .ps1 file
I then have a .bat file, IN SAME FOLDER AS THE PS1 FILE, that runs this script, and I call this .bat file at PC logon via the Task Scheduler
NB I don't have a script to put the NAS to sleep, I simply set this in the QNAP control panel for a time I want (in my case 1am)
# This is the MAC address of the NAS to wake
$Mac = "Your QNAP NAS Mac address"
# This creates the MAC address as a byte
$MacByteArray = $Mac -split "[:-]" | ForEach-Object { [Byte] "0x$_"}
# This creates the Magic Packet:
# First add start sequence
# Then do the MAC address 16 times
[Byte[]] $MagicPacket = (,0xFF * 6) + ($MacByteArray * 16)
# Send the packet
$UdpClient = New-Object System.Net.Sockets.UdpClient
$UdpClient.Connect(([System.Net.IPAddress]::Broadcast),7)
$UdpClient.Send($MagicPacket,$MagicPacket.Length)
$UdpClient.Close()
@ECHO OFF
PowerShell.exe -NoProfile -ExecutionPolicy Bypass -Command "& '%~dpn0.ps1'"
Works fine
Thank you!
Thank you!
