I'm an advanced Linux user, but I've still made a rookie mistake (screwing with configs without a backup) ...
I got my QNAP about 2 months ago and was immediately turned off with the default account "admin". I (initially) made my own secondary admin user, "misteralexander", but eventually decided to remove this user and simply rename the existing 'admin' user (usermod). Things were going great, server up and running ... all the apps I need, web interfaces ... all 100%.
Yesterday, I reboot. First time in about 24 days (no biggie, right?). I haven't done any firmware updates so the reboot was of little concern. The system comes up just fine and I resume a movie on Plex without issue.
I go to log into the Web Portal (http://192.168.0.13:8080/cgi-bin/) which has a static IP assigned to it, and I get the message that the connection was refused. I do some googling and find a suggestion to restart QtHTTPd via SSH.
I hop into an SSH session (validated by password as well as SSH Keys), so I know the credentials are fine (phew!). I try to restart QtHTTPd manually
/etc/init.d/Qthttpd.sh start
I triple-verify the credentials, even so far as to reset them (passwd) to ensure I have the proper. I even create dummy-users "mytest" with simple passwords ... same error over and over.Your credentials are incorrect or your account is no longer valid
My stomach sinks. All the processes and programs on the server are running and I can SSH in -- so whats wrong?
I'm lost and would appreciate any help! I've seen a few posts and config information is always requested .... here's what I've got:
ps
PID Uid VmSize Stat Command
1 misteralexander 616 S init
2 misteralexander SW [kthreadd]
3 misteralexander SW [ksoftirqd/0]
4 misteralexander SW [kworker/0:0]
5 misteralexander SW< [kworker/0:0H]
7 misteralexander SW [migration/0]
8 misteralexander SW [rcu_bh]
9 misteralexander SW [rcu_sched]
10 misteralexander SW [migration/1]
11 misteralexander SW [ksoftirqd/1]
13 misteralexander SW< [kworker/1:0H]
14 misteralexander SW [migration/2]
15 misteralexander SW [ksoftirqd/2]
17 misteralexander SW< [kworker/2:0H]
18 misteralexander SW [migration/3]
19 misteralexander SW [ksoftirqd/3]
20 misteralexander SW [kworker/3:0]
21 misteralexander SW< [kworker/3:0H]
22 misteralexander SW< [khelper]
23 misteralexander SW [kdevtmpfs]
24 misteralexander SW< [netns]
25 misteralexander SW< [writeback]
26 misteralexander SW< [kintegrityd]
27 misteralexander SW< [bioset]
28 misteralexander SW< [kblockd]
29 misteralexander SW< [tifm]
30 misteralexander SW< [ata_sff]
31 misteralexander SW [khubd]
32 misteralexander SW< [md]
33 misteralexander SW [kworker/0:1]
34 misteralexander SW< [cfg80211]
35 misteralexander SW [kworker/1:1]
36 misteralexander SW< [rpciod]
61 misteralexander SW [kswapd0]
62 misteralexander SWN [ksmd]
63 misteralexander SW [fsnotify_mark]
64 misteralexander SW [ecryptfs-kthrea]
65 misteralexander SW< [nfsiod]
66 misteralexander SW< [cifsiod]
67 misteralexander SW< [crypto]
91 misteralexander SW< [kthrotld]
94 misteralexander SW< [kmpath_rdacd]
95 misteralexander SW [scsi_eh_0]
96 misteralexander SW [scsi_eh_1]
97 misteralexander SW [scsi_eh_2]
98 misteralexander SW [scsi_eh_3]
99 misteralexander SW [scsi_eh_4]
100 misteralexander SW [scsi_eh_5]
106 misteralexander SW [scsi_eh_6]
107 misteralexander SW [scsi_eh_7]
108 misteralexander SW [scsi_eh_8]
109 misteralexander SW [scsi_eh_9]
114 misteralexander SW [scsi_eh_10]
115 misteralexander SW [scsi_eh_11]
116 misteralexander SW [scsi_eh_12]
117 misteralexander SW [scsi_eh_13]
122 misteralexander SW [scsi_eh_14]
123 misteralexander SW [scsi_eh_15]
124 misteralexander SW [scsi_eh_16]
125 misteralexander SW [scsi_eh_17]
130 misteralexander SW [scsi_eh_18]
131 misteralexander SW [scsi_eh_19]
132 misteralexander SW [scsi_eh_20]
133 misteralexander SW [scsi_eh_21]
138 misteralexander SW [rc0]
139 misteralexander SW< [raid5wq]
140 misteralexander SW< [dm-block-clone]
141 misteralexander SW< [kmpathd]
142 misteralexander SW< [kmpath_handlerd]
147 misteralexander SW< [deferwq]
221 misteralexander SW< [ixgbe]
222 misteralexander SW [scsi_eh_22]
223 misteralexander SW [usb-storage]
224 misteralexander SW [scsi_eh_23]
225 misteralexander SW [usb-storage]
226 misteralexander SW [scsi_eh_24]
227 misteralexander SW [usb-storage]
253 misteralexander SW< [dm_bufio_cache]
258 misteralexander SW< [bioset]
259 misteralexander SW< [kcopyd]
260 misteralexander SW< [bioset]
261 misteralexander SW< [kcopyd_tracked]
262 misteralexander SW< [bioset]
266 misteralexander SW< [bioset]
267 misteralexander SW< [drbd-reissue]
289 misteralexander SW [kworker/1:2]
290 misteralexander SW< [kworker/2:1H]
295 misteralexander SW< [kworker/3:1H]
296 misteralexander SW< [kworker/1:1H]
298 misteralexander SW< [kworker/0:1H]
342 misteralexander 556 S < udevd --daemon
448 misteralexander SW< [bioset]
449 misteralexander SW [md9_raid1]
462 misteralexander SW [kjournald]
475 misteralexander SW< [bioset]
476 misteralexander SW [md13_raid1]
718 misteralexander SW [kworker/u16:0]
1043 misteralexander 11724 S php-fpm: master process (/etc/config/apache/php-fpm.conf)
1044 httpdusr 7436 S php-fpm: pool www
1045 httpdusr 7440 S php-fpm: pool www
1130 misteralexander 2984 S /usr/local/apache/bin/apache-dav -k start -f /etc/apache-dav-sys.conf
1132 misteralexander 1856 S /usr/local/apache/bin/apache-dav -k start -f /etc/apache-dav-sys.conf
1135 misteralexander 1836 S /usr/local/apache/bin/apache-dav -k start -f /etc/apache-dav-sys.conf
1401 misteralexander 3776 S /usr/local/apache/bin/apache -k start -c PidFile /var/lock/apache.pid
1403 httpdusr 2116 S /usr/local/apache/bin/apache -k start -c PidFile /var/lock/apache.pid
1404 httpdusr 2012 S /usr/local/apache/bin/fcgi-p -k start -c PidFile /var/lock/apache.pid
1407 httpdusr 2764 S /usr/local/apache/bin/apache -k start -c PidFile /var/lock/apache.pid
1408 httpdusr 2752 S /usr/local/apache/bin/apache -k start -c PidFile /var/lock/apache.pid
1409 httpdusr 2748 S /usr/local/apache/bin/apache -k start -c PidFile /var/lock/apache.pid
1653 misteralexander 2140 S /usr/local/apache/bin/apache_proxys -k start -f /etc/apache-sys-proxy-ssl.conf
1654 misteralexander 1888 S /usr/local/apache/bin/fcgi-pm -k start -f /etc/apache-sys-proxy-ssl.conf
1657 misteralexander 2708 S /usr/local/apache/bin/apache_proxys -k start -f /etc/apache-sys-proxy-ssl.conf
1658 misteralexander 2708 S /usr/local/apache/bin/apache_proxys -k start -f /etc/apache-sys-proxy-ssl.conf
1659 misteralexander 2704 S /usr/local/apache/bin/apache_proxys -k start -f /etc/apache-sys-proxy-ssl.conf
2015 misteralexander 2536 S /sbin/hal_daemon -f
2036 misteralexander SW [kworker/3:2]
2071 misteralexander SW< [bioset]
2072 misteralexander SW [md256_raid1]
2110 misteralexander SW< [bioset]
2111 misteralexander SW [md1_raid6]
2121 misteralexander SW [kworker/2:2]
2134 misteralexander SW< [drbd1_submit]
2140 misteralexander SW [drbd_w_r1]
2188 misteralexander SW< [kdmflush]
2190 misteralexander SW< [bioset]
2233 misteralexander SW< [kdmflush]
2236 misteralexander SW< [bioset]
2262 misteralexander SW [jbd2/dm-0-8]
2263 misteralexander SW< [ext4-rsv-conver]
2293 misteralexander SW [jbd2/sdj1-8]
2294 misteralexander SW< [ext4-rsv-conver]
2370 misteralexander SW [jbd2/sdk1-8]
2371 misteralexander SW< [ext4-rsv-conver]
2460 misteralexander 708 S /sbin/lvmetad
2581 misteralexander SW [kjournald]
2801 misteralexander 3156 S sshd: misteralexander@pts/1
3163 misteralexander 836 S /sbin/daemon_mgr.nvr
3196 misteralexander SW< [cryptodev_queue]
3227 misteralexander SW [notify thread]
3235 misteralexander 256 S < qWatchdogd: keeping alive every 5 seconds...
3254 misteralexander 1544 S -bash
3329 misteralexander SW< [hd-audio0]
3719 misteralexander 432 S /sbin/netwatchdog -d
4113 misteralexander 548 S /sbin/modagent
5207 misteralexander SW< [thunderbolt]
5336 misteralexander SW< [bond0]
5339 misteralexander SW< [bond1]
5345 misteralexander SW< [bond2]
7036 misteralexander 2096 S /mnt/ext/opt/netmgr/util/redis/redis-server *:0
7079 misteralexander 7940 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/ip_monitor.py
7087 misteralexander 7836 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/redisVnicListener.py
7642 misteralexander 64 S N /sbin/dhcpcd -h NAS04CAB2 -G eth0
9391 misteralexander 26228 S Plex Plug-in [com.plexapp.agents.localmedia] /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-edef59192/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1
9635 misteralexander SW< [iscsi_eh]
9651 misteralexander SW [qnap_et]
9663 misteralexander 416 S /sbin/iscsid --config=/etc/config/iscsi/sbin/iscsid.conf --initiatorname=/etc/iscsi/initiatorname.iscsi
9664 misteralexander 2144 S < /sbin/iscsid --config=/etc/config/iscsi/sbin/iscsid.conf --initiatorname=/etc/iscsi/initiatorname.iscsi
9672 misteralexander 1588 S /sbin/vdd_control -d
9692 misteralexander 1252 S /bin/sh /usr/local/mariadb/bin/mysqld_safe --defaults-file=/usr/local/mariadb/my-mariadb.cnf --basedir=/usr/local/mariadb --datadir=/share/CACHEDEV1_DATA/.system/data --user=root --default-storage-engine
10036 misteralexander 43616 S /usr/local/mariadb/bin/mysqld --defaults-file=/usr/local/mariadb/my-mariadb.cnf --basedir=/usr/local/mariadb --datadir=/share/CACHEDEV1_DATA/.system/data --plugin-dir=/usr/local/mariadb/lib/plugin --user
10362 misteralexander 2224 S /sbin/qpkgd -d0
10518 misteralexander 166472 S /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Transcoder -codec:0 h264 -i /share/CACHEDEV1_DATA/Plex/TV Shows/The Big Bang Theory/S03E01 - The Big Bang Theory.mkv -filter_complex [0:0]scale=w=min(1280
10604 1000 2060 S /usr/local/sbin/_thttpd_ -p 8080 -nor -nos -u admin -d /home/httpd -c **.* -i /var/lock/._thttpd_.pid
10622 misteralexander 4096 S /usr/local/apache/bin/apache_proxys -k start -f /etc/apache-sys-proxy-ssl.conf
11401 misteralexander 1624 S /usr/sbin/cupsd -C /etc/config/cups/cupsd.conf -s /etc/config/cups/cups-files.conf
11808 misteralexander 4988 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/config/smb.conf
11816 misteralexander 2476 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/config/smb.conf
11886 misteralexander SW [kworker/u16:1]
11933 misteralexander 2128 S /usr/local/samba/sbin/nmbd -l /var/log -D -s /etc/config/smb.conf
12172 misteralexander 1156 S /sbin/upnpd eth0 eth0
12333 misteralexander 13552 S N /usr/local/medialibrary/bin/mymediadbserver -n -t -d -i -1
13240 misteralexander 13536 S N /usr/local/medialibrary/bin/myidbserver -n -d
16574 misteralexander 2096 S /usr/local/sbin/remote_folder_daemon --reset
16620 httpdusr 856 S /sbin/lpb_scheduler -d
16647 misteralexander SW [kworker/u16:2]
16696 misteralexander 1628 S /sbin/genthd
16801 misteralexander 536 S /usr/sbin/ntpdated
16901 misteralexander 1696 S /usr/sbin/upsutil
16996 misteralexander 1140 S /usr/sbin/sshd -f /etc/config/ssh/sshd_config -p 22
17008 misteralexander 832 S /usr/sbin/crond -l 9 -c /tmp/cron/crontabs
17426 guest 1160 S /usr/sbin/dbus-daemon --system
17842 misteralexander 384 S /usr/sbin/agent --adapter hci0
17854 guest 1580 S avahi-daemon: running [NAS04CAB2.local]
17960 misteralexander 948 S /usr/bin/lunportman
18291 misteralexander 2772 S /sbin/bcclient
18565 misteralexander 676 S N /sbin/acpid
18841 misteralexander 536 S /sbin/gen_bandwidth -r -i 5
18928 misteralexander 1260 S /sbin/lcdmond
19049 misteralexander 912 S /sbin/qsyslogd
19052 misteralexander 1044 S qNoticeEngined: Write notice is enabled...
19060 misteralexander 1736 S qLogEngined: Write log is disabled...
19065 misteralexander 1164 S /bin/sh /etc/init.d/klogd.sh start
19075 misteralexander 1020 S /sbin/qShield
19482 misteralexander 276 S /bin/dd if=/proc/kmsg of=/mnt/HDA_ROOT/.logs/kmsg bs=1 count=1024000
19593 misteralexander 1380 S /sbin/sdmd --daemon
19623 misteralexander 2116 S /usr/bin/qsnapman
19671 misteralexander 1696 S /usr/local/bin/qb_daemon -d 7
19790 misteralexander 1328 S /usr/bin/qsyncman
19927 misteralexander 1688 S /sbin/versiond
19931 misteralexander 1024 S /sbin/versiond
20058 misteralexander 1244 S /bin/sh /usr/local/mariadb/bin/mysqld_safe --defaults-file=/etc/qbox-mariadb.cnf --basedir=/usr/local/mariadb --datadir=/share/CACHEDEV1_DATA/.qbox/mysql/data --user=root --default-storage-engine=MyISAM
20390 misteralexander 53956 S /usr/local/mariadb/bin/mysqld --defaults-file=/etc/qbox-mariadb.cnf --basedir=/usr/local/mariadb --datadir=/share/CACHEDEV1_DATA/.qbox/mysql/data --plugin-dir=/usr/local/mariadb/lib/plugin --user=root --
20512 misteralexander 2072 S /usr/bin/qsnapman-alive
20544 misteralexander 888 R ps
20860 misteralexander 532 S /sbin/gen_bandwidth -r -i 5
20867 misteralexander 2248 S /usr/bin/qsnapman-recyc
21057 misteralexander 952 S /sbin/daemon_mgr
21137 misteralexander 12588 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21138 misteralexander 12156 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21139 misteralexander 12160 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21140 misteralexander 12160 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21141 misteralexander 12160 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21142 misteralexander 12160 S /mnt/ext/opt/Python/bin/python ./manage.py runfcgi method=prefork socket=/tmp/netmgr.sock pidfile=/tmp/netmgr.pid
21166 misteralexander 2028 S /mnt/ext/opt/netmgr/util/redis/redis-server *:0
21199 misteralexander 6988 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/ip_monitor.py
21207 misteralexander 7832 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/redisVnicListener.py
21213 misteralexander 8860 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/asd.py
21221 misteralexander 4476 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/nsd.py
21224 misteralexander Z [python]
21234 misteralexander 3524 S /mnt/ext/opt/Python/bin/python /mnt/ext/opt/netmgr/api/core/gsd.py
21732 misteralexander 2588 S /sbin/qbox_man -b
21747 misteralexander 2760 S /sbin/qboxd -n 2 -b -d0
21764 misteralexander 1108 S /usr/local/bin/qbox_monitor -pid:21747 -reg:/share/homes -client:qbox -filter:0x6763 -b
22151 misteralexander 2648 S /sbin/qboxd -n 1 -b -d0
22159 misteralexander 1116 S /usr/local/bin/qbox_monitor -pid:22151 -reg:/share/CACHEDEV1_DATA/Plex -client:qbox -filter:0x6763 -b
22209 misteralexander 3300 S /sbin/qboxd -n 0 -b -d0
22216 misteralexander 1364 S /usr/local/bin/qbox_monitor -pid:22209 -reg:/share/CACHEDEV1_DATA/Download -client:qbox -filter:0x6763 -b
23423 misteralexander 56856 S ./Plex Media Server
23442 misteralexander 1080 S /bin/sh /share/CACHEDEV1_DATA/.qpkg/QSonarr/start.sh
23445 misteralexander 127740 S /share/CACHEDEV1_DATA/.qpkg/Qmono/bin/mono /share/CACHEDEV1_DATA/.qpkg/QSonarr/NzbDrone/NzbDrone.exe
23459 misteralexander 27804 S N Plex Plug-in [com.plexapp.system] /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-edef59192/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.4.4.3495-e
23890 misteralexander 16116 S /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex DLNA Server
24964 misteralexander 50892 S /opt/bin/python SABnzbd.py -f //share/CACHEDEV1_DATA/.qpkg/SABnzbdplus/Config/sabnzbd.ini --browser 0 --daemon --pid /tmp
25549 misteralexander 832 S /usr/sbin/SCREEN -dmS MYTRANSCODE /usr/local/medialibrary/bin/mytranscodesvr -u -debug -db /share/CACHEDEV1_DATA
25551 misteralexander 14476 S /usr/local/medialibrary/bin/mytranscodesvr -u -debug -db /share/CACHEDEV1_DATA
26766 misteralexander 7544 S /usr/sbin/dsd -level error -log /share/CACHEDEV1_DATA/.qpkg/DSv3/log/dsd.log
26940 misteralexander 2020 S /sbin/upnpcd -i 300
26988 misteralexander 468 S /sbin/mcelog --daemon
27287 misteralexander 560 S /sbin/getty 115200 tty1
27288 misteralexander 564 S /sbin/getty 115200 tty2
27656 misteralexander 1300 S /usr/sbin/bluetoothd
28976 misteralexander 3512 S /usr/lib/thunderbolt/thunderboltd
29644 misteralexander 73004 S /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Transcoder -codec:0 mpeg4 -i /share/CACHEDEV1_DATA/Plex/Documentaries/Moses.avi -filter_complex [0:0]scale=w=min(720\,iw):h=min(416\,ih):force_original_as
31285 misteralexander SW [kworker/2:1]
Filesystem Size Used Available Use% Mounted on
none 250.0M 196.3M 53.7M 79% /
devtmpfs 7.8G 8.0k 7.8G 0% /dev
tmpfs 64.0M 264.0k 63.7M 0% /tmp
tmpfs 7.8G 32.0k 7.8G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/md9 509.5M 112.1M 397.4M 22% /mnt/HDA_ROOT
cgroup_root 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA
/dev/sdj1 231.8G 19.7G 211.6G 9% /share/external/DEV3302_1
/dev/sdk1 5.4T 447.7G 5.0T 8% /share/external/DEV3303_1
/dev/md13 371.0M 295.2M 75.8M 80% /mnt/ext
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Web
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Public
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/homes
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Plex
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Download
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/Multimedia
/dev/sdj1 231.8G 19.7G 211.6G 9% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/external/DEV3302_1
/dev/sdk1 5.4T 447.7G 5.0T 8% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/external/DEV3303_1
/dev/mapper/cachedev1 32.0T 5.4T 26.6T 17% /share/CACHEDEV1_DATA/.qpkg/CodexPack/mnt/share/CACHEDEV1_DATA/.system
tmpfs 64.0M 264.0k 63.7M 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/tmp
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/sys/fs/cgroup
udev 7.8G 8.0k 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/dev
tmpfs 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/run
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/run/shm
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/run/lock
none 7.8G 0 7.8G 0% /share/CACHEDEV1_DATA/.qpkg/CodexPack/run/user
md1 : active raid6 sda3[0] sdf3[7] sde3[6] sdh3[5] sdg3[4] sdd3[3] sdc3[2] sdb3[1]
35103403008 blocks super 1.0 level 6, 512k chunk, algorithm 2 [8/8] [UUUUUUUU]
md256 : active raid1 sdf2[7](S) sde2[6](S) sdh2[5](S) sdg2[4](S) sdd2[3](S) sdc2[2](S) sdb2[1] sda2[0]
530112 blocks super 1.0 [2/2] [UU]
bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sda4[0] sdf4[7] sde4[6] sdh4[5] sdg4[4] sdd4[3] sdc4[2] sdb4[1]
458880 blocks super 1.0 [32/8] [UUUUUUUU________________________]
bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sda1[0] sdf1[7] sde1[6] sdh1[5] sdg1[4] sdd1[3] sdc1[2] sdb1[1]
530048 blocks super 1.0 [32/8] [UUUUUUUU________________________]
unused devices: <none>
TS-X71
4.2.4
20170313
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WX41DA57HNAN
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WXB1HB4L5VWT
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WX41DA57HZJ5
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WXB1HB4WPW6R
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WXB1HB4H9EFY
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WX11DB514CF4
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WX11DB514K1D
Model=WDC WD6001F9YZ-09YUWL1 , FwRev=01.01E03, SerialNo= WD-WX11DB5149K3
Model= , FwRev=, SerialNo=910036EB93C52772
Model=aSsmnug, FwRev=, SerialNo=214365879C7D
Model=eWtsre niDigatl, FwRev=, SerialNo=13134433533483039563
