Hi everyone..
I am in the process of installing a new NAS QNAP TS-251A.
While uploading file, the system is generating a message asking for desired action for the uploading file if the files already in the folder have same name. However, i dont have any files uploaded in the folder. The system seem to be generating the message for every upload regardless of whether there is already file of the same name or not.
I want the message to be generated only if there is similar file name already in the folder.
Is there any way to customize the system message?
How to customize the system messages generated while uploading file
Re: How to customize the system messages generated while uploading file
Uploading how?
Where and how is the message shown?
This message as belows is shown before every file upload even when i have no file with the same name in the folder.
? system message
For files with the same name, how do you want to handle them?
(.) skip the files
(.) overwrite the files
(.) Rename if a file exists with the same name
Please suggest how to make it intelligent enough to give the message only if a file of same name already exists in the folder.
? system message
(.) skip the files
Uploading from what kind of device using what kind of app/tool/service?securityunit wrote:This message as belows is shown before every file upload...
