Hi All,
Currently have privilege access integration & it requires additional user with admin privilege that able to login using SSH, how to do such thing ?
I created additional user with full privilege but unable to login using SSH.
any thought ?
Thanks in Advance
Another admin level user with SSH capabilty
Re: Another admin level user with SSH capabilty
In older cat1 NAS models only the admin user can log in via SSH.
In newer cat2 NAS models using later firmware you can configure which user can log in with SSH.
