"URL /qcenter/ was not found on this server"
Ah... why? Shows it's running. I got the login screen and entered my credentials...
Re: "URL /qcenter/ was not found on this server"
Nobody has any idea how this is meant to work?
How do you control what port q'center is on? I have a bunch of servers with competing ports, so I setup an nginx proxy, if I put my qnap on 80/443 and try to login to q'center it takes my login and then pushes me to 8080 for some reason. If I set it to 8080 and login it pushes me to 8810 and gives me a not found, and I don't see anywhere how I can control this from the UI.
