Hello all
I have a TS-231p and I am trying to setup Kodi on my fire stick to add a folder from my QNAP to use as a library for my movies but Kodi does not scape the movie data it works from my Mac folders or mycloud drive but can't get it to work on Qnap.
I have had it working before but after I wiped my QNAP after being hacked I can't get it to work now and not sure why.
I am now on TS-131P_231P_431P_X31+_20191005-4.4.1.1081 firmware since wiping any help setting up would be great thanks.
Kodi can't scape movies
- Trexx
Re: Kodi can't scape movies
What protocol are your trying to connect with (SMB or NFS)?
Did you re-enable remote access to the shared folders (or give guest access) on your QNAP? My guess is that is likely where your issue is coming from, as by default I believe it will be denied.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I have sorted it now was using NFS but the problem was with Kodi I reinstalled Kodi and got it working again thanks
