[Antivirus] Failed to update virus definitions
Q'center app, Helpdesk app
cabman
Re: [Antivirus] Failed to update virus definitions
Post by cabman »
vel0x wrote: Thu Jan 23, 2020 12:31 pm Had the same issue.
Somehow my default system volume was not set in the config.
Using SSH:
[/etc/config] # getcfg SHARE_DEF defVolMP -f /etc/config/def_share.info
Fixed it using (you may need to adjust this if you use a different volume as your system volume):
[/etc/config] # setcfg SHARE_DEF defVolMP -f /etc/config/def_share.info /share/CACHEDEV1_DATA
After that it looked like this:
And the updates started working again after this.
I am having this issue now after a power failure. I cannot understand how to enter this using SSH. Do I enter each line, press enter then do the next line and so on until all 3 lines are entered? I have never used SSH before. I figured out how to logon to my QNAP using SSH. When I put these lines of code in it appears that nothing happens. Which part of the code would be the volume...."defVolMP"? Any clarification would be appreciated. Is it possible to provide instructions as if someone has never done this before?
ecoen
Post by ecoen »
cabman wrote: Wed Apr 21, 2021 10:41 pm
The volume portion of the command is in the 2nd line of commands... in his example (and on my NAS), it is /share/CACHEDEV1_DATA .
If you are ssh'ed in, you can find the volume by figuring out where your NAS user homes directory lives:
ls -al /share/homes
lrwxrwxrwx 1 admin administrators 20 2021-05-04 08:46 /share/homes -> CACHEDEV1_DATA/homes/
As you can see, in my example the volume that I want to use is going to be /share/CACHEDEV1_DATA .
surfdude
First post
Post by surfdude »
Hi! Have a same problem.
For me, the advice above didn't work. What am I doing wrong?
[~] # ls -al /share/homes
lrwxrwxrwx 1 admin administ 14 Jul 8 14:10 /share/homes -> MD0_DATA/homes/
[~] # [/etc/config] # getcfg SHARE_DEF dfVolMP -f /etc/config/def_share.info
-sh: [/etc/config]: No such file or directory
[~] # [/etc/config] # setcfg SHARE_DEF defVolMP -f /etc/config/def_share.info /share/MD0_DATA
[~] # [/etc/config] # getcfg SHARE_DEF defVolMP -f /etc/config/def_share.info
dolbyman
Post by dolbyman »
probably a device that uses cachedevx and not MDx_data
without information, impossible to say
daNutz
Getting the hang of things
Post by daNutz »
Ive had this in the past and manually downloading the latest .cvd from https://database.clamav.net/daily.cvd, importing and then running
freshclam -u admin -v
in the console and brought everything up to date.
TS-1079Pro - 30TB - RAID 6 - FW: 4.3.6.2232 - MultiMedia
TS-453 Pro - 12TB - RAID 5 - OS: Ubuntu Server 22.04.2 / Docker
SelfHosted
NAS Migration Compatibility
cachi
Post by cachi »
daNutz wrote: Sat Aug 07, 2021 11:08 pm Ive had this in the past and manually downloading the latest .cvd from https://database.clamav.net/daily.cvd, importing and then running
Thanks!!! That saved me right now!! I've bookmarked that URL!
Regards
mafabio
Post by mafabio »
Great vel0x! Your fix worked after a reboot. Thank you!
Using SSH:
brxxm
Post by brxxm »
I had this problem since beginning this week - following a power failure my TS-453A would not reboot. It turned out disk 1 was damaged. Disk 1 is part of a RAID 1 volume (i.e. mirrored) with disk 2. This RAID 1 volume is the system volume.
After removing disk 1 the NAS booted successfully. I put a spare disk in slot 1 and waited for the NAS to rebuild the volume. The rebuild completed and all was good again except antivirus did not update and raised the missing volume warning.
The fix of vel0x solved this. I can not explain why the defVolMP setting was not restored with the rebuild.
ensignvorik
Easy as a breeze
Post by ensignvorik »
Someone else suffering this issue after a power failure, and as others have reported, doing the below seems to sort it.
Using SSH:
Unless I'm being blind, I can't find the setting to change what kind of QNAP I have on my profile. I now own a TS-253A
Flynnstones
First post
Post by Flynnstones »
I am also having the same issue as Surfdude.
Getting this after each line entered:
My volume is /share/CACHEDEV1_DATA.
Has anyone any idea what the issue could be? I fixed it using this method in the past and it has come back after a power cut unfortunately.
Locked
Return to “NAS Management”
