Add user to sudoers
Add user to sudoers
Hi!
For security reason I'd disable the standard admin user and created a new one in the Administrators user group. Yet this user is not allowed everthing on the system (swapoff for instance is denied and is allowed to Admin). Also it is not allowed to sudo.
How do I add a new administrator user to the sudoers? (there is no visudo available )
QNAP TS-453mini
Firmware: up to date
Re: Add user to sudoers
login to your Qnap via ssh with admin user
edit /usr/etc/sudoers file
and add the following line
ssh admin@your-nas-ip
vim /usr/etc/sudoers
your-user-name ALL=(ALL) ALL
- OneCD
Last time I checked, QTS doesn't use 'sudo'.
Can someone please confirm if there exists a [/usr/etc/sudoers] file on their NAS?
I have that file .. yes (every single line commented out on my 853Bu)
actually this one is not commencted out
## User privilege specification
admin ALL=(ALL) ALL
httpdusr ALL=(ALL) NOPASSWD:ALL
- OneCD
Thanks @dm.
What firmware version is that?
Do you have a working ‘sudo’ binary too?
- OneCD
oh you meant the program that reads the config file .. lol
here:
here:
[~] # which sudo
/usr/bin/sudo
- OneCD
Hmm, so QTS now has 'sudo' ... nice!
I'll remove my suspicions from my first post.
the sudoers file is recreated by some script in the qnap each time the nas is restarted. unleast you find the script and modify it (with a potential brick in the next restart because a sintax error) you'll have to recreate the modification every time your nas is rebooted... you could do it with a cron script that adds the user to the sudo group
I'm having the same problem.
Can someone please post a working solution for this?
solution to add to sudo (and modify startup to make it "permanent") was already posted further up
0. Create your own username and edit the access permission for SSH in the QNAP controlpanel
1. Install Entware
2. Login as admin with ssh.
3. opkg update
4. opkg install sudo
5. Edit /opt/etc/sudoers and add "<yourusername> ALL=(ALL) ALL"
6. Logout and login with your own username
7. In the user directory add a file with the name ".profile" and add the line "export PATH=/opt/bin:$PATH"
8. logout and login DONE
1. Install Entware
3. opkg update
Can you explain how you can install Entware in detail?
I tried to follow your steps, but I found it to be difficult to replicate.
It must be missing some intermediate steps...
- OneCD
Hi Paul and welcome to the forum.
As you have asked, I see a big red-flag that you're probably trying to solve a problem the wrong way.
May I ask: what are you trying to fix?
I'm wondering if you really need the advice in this topic then? This topic is for those with some experience at the command shell - at least enough that they don't need to ask how to install Entware.
