Random Shutdowns after about 24h operation
I ran in to the issue, that my NAS TS-231P shutdowns randomly, without any interaction. The device can be started again with an Wake-On-Lan or with the power button. I did reinitialize the device and reconfigured it with NFS and SMB.
Is there any possibility to get further information on the system? (There is also no power schedule for automated shutdowns....)
The system log contains:
Severity Level Date Time Users Source IP Application Category Content
Information 2020/08/06 09:28:20 System 127.0.0.1 Power NAS Power Status [Power] System shut down on Thu Aug 6 09:28:19 CEST 2020.
Any help is appreciated.
Kind greetings
Kind greetings
- Moogle Stiltzkin
Re: Random Shutdowns after about 24h operation
what qts are you using?
NAS
Network
Resources
Network
Resources
the software is the latest:
4.4.3.1381 build 20200729
- Moogle Stiltzkin
did you test ram? in case it went bad. one possible reason for random shutdown.
https://www.youtube.com/watch?v=i8wsYkd-2SA
NAS
Network
Resources
Network
Resources
- Moogle Stiltzkin
also what is your configuration. single disks? raid1? raid0? jbod?karel.krobath wrote: ↑Fri Aug 07, 2020 5:10 pm the software is the latest:
are you using compatible hdds? or are you using desktop model hdds? did you run smart test see what their status is?
NAS
Network
Resources
Network
Resources
thanks for the ram test suggestion. i will do that... and post the results
Moogle Stiltzkin wrote: ↑Fri Aug 07, 2020 5:23 pm
i have a raid1, the disks are OK in the test, disks are supported according to the qnap web site.
what annoys me the most is, that the source for the shutdown is missing in the log. that would be very helpful for further troubleshooting.
Good morning Everybody,
I have the same issue that appear randomly on several units, same models,
we have 2 QTS231+ that gives always the same result (Shutdown) after Network and virtual switch Stop....
(attached log), it could happend with and without operations running on it....
We found a freaky solution with a WOL procedure that runs every hour...
Everything seems correct,
HDD compatible
RAM ok
This happend randomly on every NAS
same result with old and new firmware...
Looking on all the operations that runs in that time (around 03 AM in this case) I found the Malware remover,
disable it but nothing changes....
HELP
HDD compatible
RAM ok
HELP
- Moogle Stiltzkin
try updating to the latest 4.5.3.1670 build 20210515
https://www.qnap.com/en/download?model= ... y=firmware
NAS
Network
Resources
Network
Resources
Dear mand0,mand0 wrote: ↑Thu Jun 03, 2021 3:46 pm Good morning Everybody,
HDD compatible
RAM ok
HELP
I am having the same issue now with my TS-231P, ie. (Shutdown) after Network and virtual switch Stopped. Did you manage to find a solution? Really frustrating that it keeps shutting down every few days. Appreciate very much if you shed some light on this issue.
Thank you in advance and have a nice day.
regards
Johnny Tay
open a ticket with QNAP, you will unlikely get an answer from a 1 time poster from a year ago
Noted. Thanks dolbyman.
Have a nice day.
Have a nice day.
johnnytay67 wrote: ↑Wed Sep 07, 2022 6:26 pmDear mand0,mand0 wrote: ↑Thu Jun 03, 2021 3:46 pm Good morning Everybody,
HDD compatible
RAM ok
HELP
regards
Johnny Tay
Its 2022 and we are having the same issue with one of 4 QNAPs, new and updated, original hardware ... Did you guys find any solution to this? (Also i found, the QVPN Service does schow some strange error when clicking on QBELT and PPTP: "Unknown Error" ... maybe related.
even in 2022, opening a ticket is still the thing to go with (as advised earlier)
btw in 2022, you should stay far away from pptp
- Moogle Stiltzkin
on QNAP there is a power scheduled. was there anything configured there? BY default this setting is disabled. But if someone configured this, it's possible for the NAS to automatically shutdown on a set timer schedule.
random shutdowns could also possibly be bad ram, or other hardware issues. Or in my case last time it was a BAD FIRMWARE. Or maybe it could be a malware issue perhaps? MY random reboot issues got solved by updating to a new firmware (this is specific to my own issue, and may not necessarily be what is going on for you. i'm just providing an example of a possible reason) and doing a clean reinitialize to reinstall QTS.
That's all i can think of as to what is possibly going on here. For better help, best ask helpdesk like others pointed out.
for vpn protocol, only use either openvpn or wireguard
Did you try reinitializing the nas? to see if that helped with resolving this?
so out of those 4, only that 1 model has the issue yes?one of 4 QNAPs, new and updated, original hardware .
NAS
Network
Resources
Network
Resources
