Following an unexpected shutdown, I can no longer access the administration login page of my QNAP. It is accessible to users and I can access it via ftp and via file explorer. However, from Qfinder instead of going to the login page when I click "Login", I get redirected to an a app (DVBLINK) and I get an application error where I am stuck and cannot navigate elsewhere. I get the same message no matter what client I am using and also when I enter the login page path manually.
Any ideas how to clear this?
Unable to login via browser
Re: Unable to login via browser
did your admin page change ports? if that app is using port 80 (or whatever)
How do I change the apps port? The admin page is on port 8080
normally in the GUI
side question, did you install that DVBLINK app on your NAS, or does that come out of the blue ?
