IP Attack
IP Attack
This morning, having had my TS-251D for about 3 weeks, I am now inundated with numerous failed IP logon attempts to the admin account. I have the necessary auto block IP's in force but wondered should I create a new admin user and disable the default admin account?
Re: IP Attack
I have the same issue starting late yesterday 3/22. 99% of the IP addresses are used once then they move on to another one. The same percentage all originated from China. Is there a way to force a delay in the logon attempt is the admin fails to logon?
Re: IP Attack
get your nas out of the web, if expoits are used, you will never get a message
- spile
- Been there, done that
Re: IP Attack
Have you followed the steps in Security Counsellor?
Re: IP Attack
I have indeed however coincidently all these attempts have now stopped?
- GTunney
Re: IP Attack
I've just had another spout of them right now.
Model: TS-453D 8GB
Disks: 3 x 4TB Western Digital WD40EFRX - RAID 5
Total Storage: 7.2TB
Applications: Plex | Sonarr | QSabnzbd+ | Radarr | Home Assistant | MQTT/Z2M
Other Devices: Netgear D7000 AC1900 VDSL Router | FTTP - 1014/104 | Netgear GS108 Gigabit Switch
- Moogle Stiltzkin
Re: IP Attack
do not expose your nas to the world wide web. then these attacks SHOULD stop. because your nas should be on your lan behind a router (with firewall) to protect you from people on internet. then they can't talk to your nas IF you do not expose your nas or your internal network and the devices in them to the internet
not sure what router you are using, but pfsense by default is already considered secure. e.g. firewall enabled, upnp not enabled, no port forwardings at all,
this is pfsense update frequency
https://www.reddit.com/r/PFSENSE/commen ... e/feknvjf/
some other brands like asus tend to be slow on that, to the point that third parties like merlin had to step in and offer third party firmware with more frequently updated security patches.
dlink and asus lack of security updates were so bad that at one point they were both hit by the fcc requiring security audits on their router security patching policy
https://www.zdnet.com/article/asus-hit- ... -security/
https://www.theverge.com/2019/7/4/20682 ... ty-hacking
myqnapcloud and cloudlink disable and uninstall that for starters. you don't need it these apps are the ones that tend to try and make your nas available remotely. something you don't want to do normally.
i would instead recommend using vpn on router, if remote access is a requirement. and even that has further requirements for further reducing risk of attacks, like ensuring you update qts and client devices regularly etc
https://www.youtube.com/watch?v=PgielyUFGeQ
NAS
Network
Resources
Network
Resources
- jaysona
Re: IP Attack
If you're going to refer to article, you might as well make sure the references are accurate.Moogle Stiltzkin wrote: ↑Wed Mar 24, 2021 6:02 pm ...
The FCC (Federal Communications Commission) has no oversight or authority for security of consumer devices, that falls (partly) under the purview of the FTC - Federal Trade Commission.
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
- antik
Re: IP Attack
TVS-h1288X-W1250-128G (850W) + T3 card + QXG-10G1T + GIGABYTE RTX 4080 Super Gaming OC 16G (Silent FW) + 2x 2TB M.2 NVMe Kingston KC3000 (RAID0 - apps, Qsync, VM's) + 12x 2,5“ 3,84TB SATA SSD Kingston DC600M (RAID5 - VM's, data).
TVS-1282T3-i7-48G (450W) + QXG-10G1T + PALiT GeForce GTX 1660 Super GP OC + 2x 1TB M.2 NVMe ADATA SX8200PNP (RAID0 - apps) + 4x 2,5“ 3,84TB SATA SSD Samsung PM883 (RAID5 - data backup) + 8x 8TB Seagate IronWolf Pro (RAID6 - data backup).
TS-677-16GB + 1x 256GB SSD Samsung EVO (apps) + 3x 8TB Seagate Exos (RAID0 - QVR Pro cameras recording)
Network stuff (priority use of 10GbE): QHora-301W, QSW-804-4C, ASUS XG-U2008 and TP-Link TL-SG1008MP. Protected by 2x APC CYBERFORT II 700VA.
Re: IP Attack
Antik
Those links were very insightful and useful, many thanks
- Xmantium
Re: IP Attack
Its now happed to me. Surely qnap can stop this kind of attack
Looks like a bot trying use different IP address every few minutes
Heres a few guides you can follow - https://www.qnap.com/en/how-to/faq/arti ... ount-admin
- jaysona
Re: IP Attack
Lol! There are very few people in the world that can stop a bot attack, least of all QNAP.
Just do not make ports 8080 & 443 accessible to the Internet, and there will be no attack to your NAS.
- jaysona
Re: IP Attack
Re: IP Attack
made my daydolbyman wrote: ↑Tue Apr 13, 2021 9:55 pm @jaysona
see here how well he listens
viewtopic.php?f=345&t=160407
