Disabling the deault admin
I have a TS-431P3 NAS which I have registered on mycloud and enabled QTS Desktop. Recently I discovered multiple failed login tries from IP addresses which were not mine.
The NAS also disabled access after some tries temporary to the attacker IP address which finally stopped after more than 200 tries (probably used a script). I did not change the default password which is part of the MAC address of the machine, but for safety I created a new user which I made an admin and disabled the default admin account.
My questions are
1.In case of losing the alternate admin password will the reset button re-enable the default admin or it just resets the password to the default (which is already set)
2. Is there some action that cannot be done by an alternate account which has the admin privilege?
3. Is there any other option for furtherly securing my NAS from similar attacks, except of disabling the QTS Desktop completely?
I have Firmware version one version back from the latest. 4.5.2.1566
My questions are
Re: Disabling the deault admin
Dont bother disabling admin..get your NAS out of the web and those attacks will stop
Just look at the dozen threads with the same topic from last week (search)
Thank you
I saw the other posts and took some action. I also saw the qnap suggestions on security.
- Xmantium
- Been there, done that
can someone give me step by step guide how to block external ip access to my QNAP
past 3 days i have had 1000 failed access all with different ip address
remove port forwarding on router
disable upnp on router
- Xmantium
is there not a way to block remote login?
im using apps that require internet access
the apps expose you to risks as they are poorly programmed
remove open access or suffer the consequences
- Xmantium
can someone please provide me a step by step guide to block external access
theres a bot trying to login every two mins with a different ip adresss
I just did...you did not disclose your router modell..how is there supposed to be any step by step help?(how about reading the router manual?)
right now you are just repeating yourself like a bot
- Xmantium
theres a way to do on qnap settings
auto router config can be disabled from the myqnapcloud menu
there is no way to remove manual port forwards via the NAS (as they are setup on the router)
- Xmantium
What about this option?
Blocks external ip
Blocks external ip
by that point they are already reaching your NAS .. prevent the router from forwarding traffic to your NAS
- Xmantium
Guys follow this guide - https://www.qnap.com/en/how-to/faq/arti ... ount-admin
Please QNAP, make a new release thats stop these bot attacks
Qnap does not come here .. you should know that
https://www.qnap.com/en/security-news/2 ... ce-attacks
And if you ignore everything I say .. why even ask ?To take steps to avoid being hacked, QNAP recommends that users do not expose their devices on public networks.
