TS-419II WEB LOGIN FAIL
Q'center app, Helpdesk app
josh909
Post by josh909 »
HI guys
Been trying to figure this one out for a while now....
Just suddenly got the ERR_CONNECTION_RESET when trying to connect to my NAS web login.
I can ssh to it no problem and login.
I cannot see my shared drives either on it.
My QFinder Pro can see it as well.
Running the latest firmware 4.3.3.1693 which I updated quite some time ago.
I've tried a few things to get it going but nothing yet.
I've read a few other older posts and tried most of their solutions as well.
The drives are all fine and the volume mounts ok.
Any suggestions would be a great help.
dolbyman
Re: TS-419II WEB LOGIN FAIL
Post by dolbyman »
try adding :8080 at the end of the address
josh909
Post by josh909 »
yes done all that....
I think my DNS is screwed up as it tells me LAN 1+2 DNS is another incorrect address as I have previously configured.
LAN 1+2 being my virtual switch...
Any idea how to modify the DNS of the virtual switch via ssh commands...?
Thanks.
dolbyman
Post by dolbyman »
there is no virtual switch on a 419pII
also make sure you just use 1 LAN port on the NAD, there is no need for two (it is not fast enough to sayturate a single 1GbE port)
Return to “NAS Management”
