I've tested the xopero backup here on the QNAP, and now I would like to clean it out completely.
If I just to a simple uninstall it seems to remember the storage, the users and the devices.
How do I clean it out 100%?
Complete cleanout of Xopero from QNAP?
- fribse
Best regards
Fribse
NO, RAID is NOT backup - Use RAID-Certified 24x7 drives for raid
HOWTO's:
Make automatic backup of ALL MySQL databases http://forum.qnap.com/viewtopic.php?f=32&t=15628
NAS-659 Pro II (3 GB Ram), Raid1, Survailance station, local backup destination + NAS-853A (16 GB Ram), Virtualization Station, Plex, iDrive
Network: Fritz!Box 7560 + 24p SG200 + 2x8p SG200 + 8p POE EdgeCore + 300/300 mbit Internet
Fribse
HOWTO's:
Re: Complete cleanout of Xopero from QNAP?
Hi @fribse,
you can remove storage manually but there is also database which you should remove from your QNAP after unistallation. Database is located in: /share/CACHEDEV1_DATA/xopero_postgresDB_9.5 and you can remove entire directory. Just login over SSH.
Regards,
Grzegorz Bąk
Regards,
Grzegorz Bąk
Ive manually removed the app and storage. and SSH'd in and removed the Xopero repo and Xopero Postgresdb folders, but I still seem to have the xopero process running in the background in the resource monitor.....
- OneCD
