I had upgraded to QTS 4.3 from factory default and eventually got NFS shares working ok using the linux fstab mount entry
192.168.n.nnn:/Backups/Homedir /mnt/Home_Backup nfs auto,noatime,nolock,bg,nfsvers=4,intr,tcp,actimeo=1800 0 0
I redid all the shared folders, and made sure the NFS share access was enabled properly. But I kept getting a mount error for the nfs shares.
Eventually I found that I had to change the entry "nfsvers=4" to "nfsvers=3", which then let me mount the shares with no errors.
So, is this something to be concerned about, or is nfs v4 simply not available in 4.2.2?
I mean I really don't care if everything continues to work ok nfs v3, but if it has problems v4 took care of, I would rather have the latest/greatest...
Thanks!
