I have install Deluge and Sonarr onto a Raspberry PI and I have ran into a little problem
I am having an issue seeing / using the NAS NFS Share which I set up on my NAS.
I am able to mount a folder to the share via the below method but when I go to my Deluge or Sonarr then they are not able to see or use the mount folder.
Sudo nano /etc/fstab
//192.168.0.7/media /home/pi/tank cifs username=admin,password=admin,_netdev,x-systemd.automount
Side point. I have just attached a USB Pen drive to my Deluge / Sonarr machine, and created a mount. So, that I can check to see if Deluge can see this storage area.Control Panel / Win/Mac/NFS
Enable on NFS, and then set up the NFS Host Access
Host IP *
Permission Read/Write
Squash Option = No Root Squash
Anonymous GID
Anonymous UD
So, my question is. Do I need to set up this raspberry with NFS connections so that it can see my NAS Share folder? or is it a permissions problem, as I have hit a brick wall and I don’t know what to look at next.
