i got a TS-412 with Firmware 4.2.3,
i want to mount it on my Raspberry PI 3 with latest Noobs, Jessie.
I created a User pi with matching password on my qnap für cifs and also made nfs access (full access, no_root_squash, uid to pi - jumps back to guest on reload but was saved as pi, allowed ip's either * or 192.168.179.0/24, matching to my used ip range)
directorys on the pi3 are existent, the first share from /etc/fstab is working.
now i try for exemple:
sudo mount //nas/Filme /media/plex/filme -t cifs -o username=pi,password=xxx,defaults,rw
mount error(127): Key has expired
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
if the nfs part world work i would remove the cifs entrys of course, they are just there for testing
or now with nfs:
sudo mount nas:/Filme /media/plex/filme -t nfs
mount.nfs: access denied by server while mounting nas:/Filme
//gbquadplus/Harddisk /media/gigablue cifs username=root,password=xxx,rw,file_mode=0777,dir_mode=0777
//nas/Filme /media/plex/filme cifs username=pi,password=xxx,rw,file_mode=0777,dir_mode=0777
//nas/Serien /media/plex/serien cifs username=pi,password=xxx,rw,file_mode=0777,dir_mode=0777
//nas/Musik /media/plex/musik cifs username=pi,password=xxx,rw,file_mode=0777,dir_mode=0777
//nas/Daten /media/daten cifs username=pi,password=xxx,rw,file_mode=0777,dir_mode=0777
nas:/Filme /media/plex/filme nfs auto 0 0
nas:/Serien /media/plex/serien nfs auto 0 0
nas:/Musik /media/plex/musik nfs auto 0 0
nas:/Daten /media/daten nfs auto 0 0
sudo mount -a
mount.nfs: access denied by server while mounting nas:/Serien
mount.nfs: access denied by server while mounting nas:/Musik
mount.nfs: access denied by server while mounting nas:/Daten
I don't know if its together with my issue that the nas tells me thts is can't reach the dns.
also tryed here a few things, none working.
i got a Fritz.box 7490 with upnp for nas enabled, nas is able to open ports, app downloads on nas working fine, can't access qnap cloud with it.
edit: also tested with security on:
pi@raspi:~ $ sudo mount -t cifs //nas/Filme /media/plex/filme -o username=pi,password=xxx,sec=ntlm
