QNAP NFSv4 ubuntu mount user mapping
Discussion about using NAS on Linux and Unix OS.
piovrasca
First post
Post by piovrasca » Wed Jan 24, 2018 7:47 pm
I'm unable to map client username to server username when I mount a QNAP storage on Ubuntu client with NFSv4 (I don't want to use the UID correspondence). In my case neither the UID and the username are equal in both the client and the server.
SERVER (QNAP):
I've enabled NFSv4 sharing, then I've configured a shared directory(`shared_dir`) with:
- Host/IP/Network = <client IP addr>
- Permissions = r/w
- Squash option = NO_ROOT_SQUASH
I've modified the file /sys/module/nfs/parameters/nfs4_disable_idmapping from 'Y' to 'N' (according to what I read on other forum answers).
I've rebooted the QNAP
I HAVEN'T modified the file /etc/idmapd.conf that currently is like this:
[General]
Verbosity = 9
Pipefs-Directory = /var/lib/nfs/rpc_pipefs
Domain = localdomain
[Mapping]
Nobody-User = guest
Nobody-Group = guest
CLIENT (Ubuntu 16.04):
nfs-common was already installed, so as for the server I wrote 'N' in /sys/module/nfs/parameters/nfs4_disable_idmapping.
In addition I've modified the file /etc/idmapd.conf like this:
[General]
Verbosity = 0
Pipefs-Directory = /run/rpc_pipefs
# set your own domain here, if id differs from FQDN minus hostname
[Mapping]
Nobody-User = nobody
Nobody-Group = nogroup
[Translation]
Method=static
[Static]
jameswhite@<QNAP IP addr> = james
Then I've performed the restart with service nfs-idmapd restart (I don't know why it ask me to authenticate for `org.freedesktop.systemd1.manage-units`, but I think this is not relevant for my problem)
Finally I've mounted the QNAP with:
sudo mount -v -t nfs4 <QNAP IP addr>:/shared_dir /mnt/shared_dir
Chisonne
Re: QNAP NFSv4 ubuntu mount user mapping
Post by Chisonne » Sun Oct 18, 2020 10:06 pm
Hi
Did you ever succeed to get this to work?
cheers
Charlie
Return to “Linux & Unix (NFS)”
