Setting NFS export options on shared folder
Discussion about using NAS on Linux and Unix OS.
userman93
Post by userman93 »
Is there a way to set the all_squash,anonuid and anongid export options on a shared folder on my qnap?
userman93
Re: Setting NFS export options on shared folder
Post by userman93 »
*bump*
grouillier
Post by grouillier »
I'm very inexperienced with QNAP, as I've only had my first device - a TS-230 - for about a week. However, I've been trying to figure out the NFS capabilities over the last couple days, and I *may* have the answer to your question. If not, I apologize for wasting your time.
  1. In Control Panel, under Privilege select Shared Folders.
  2. In the resulting list of Shared Folders, for the folder of interest, in the Action column, click the 2nd icon, Edit Shared Folder Permission.
  3. In the resulting dialog Edit Shared Folder Permission, change the Select permission type dropdown to NFS Host Access. I now see the following:
  4. The last two columns allow you to select the anon uid and anon gid.
Hope this helps.
TS-230, TS-253A, both with latest stable QTS
Return to “Linux & Unix (NFS)”
