Linux kernel >= 5.16.10 and issues with Qnap NFSv4
I just want to raise attention and warn everyone here that changes in NFSv4 introduced in Linux kernel 5.16.10 are not compatible with Qnap NASes.
You can get the details at:
https://bugzilla.redhat.com/show_bug.cgi?id=2055362
where some folks have pinpointed where the problem lays.
I hope this will avoid someone else to screw up wondering why their shares are not mounted anymore...
Re: Linux kernel >= 5.16.10 and issues with Qnap NFSv4
I started using NFSv3 till NFS4 gets fixed. There is also a debian bug report on this.
https://bugs.debian.org/cgi-bin/bugrepo ... ug=1006518
This is the bug report not sure if its related or not. However the same symptoms are happening.
Temporary workaround on my side, force vers=4.0 in the /etc/fstab of the client.
I can confirm that this is happening on my QTS 5.0.0.1932 which has kernel-5.10.60 with client Fedora F35 (kernel-5.16.10+).
I am mounting through fstab :
nfs4 x-systemd.automount,x-systemd.idle-timeout=15min,rw,sync 0 0
I confirm that mount parameter fixed my problem with the hanged-out command mount.nfs.
Arch Linux
Kernel: 5.17.1-arch1-1
Thx!
-o nfsvers=4.0
Arch Linux
Thx!
Can you please give a little more detail here?waldauf wrote: ↑Tue Apr 05, 2022 3:27 am I confirm that mount parameterfixed my problem with the hanged-out command mount.nfs.Code: Select all
-o nfsvers=4.0
Arch Linux
Thx!
I am a noob and mostly forgetful, so I set things up like a mount for my QNAP NAS, and I forget it, and just use it.
It is broken now and I am trying to find a way to use this for work until a fix comes out.
My way of mounting before was through /etc/fstab with the line:
10.0.0.173:/NAS_BRIDGE /home/jim/NAS_LINK nfs4 defaults,_netdev 0 0
if I offer sudo mount -a in a terminal it just hangs there. Oh! lights just went off! That is what you meant by "hanged-out command"?
Anyway... if you have found a way to make this work in my Manjaro system, please give the details so I might have a chance to mirror your success?
Thank you kindly!
Wowser!
I figured it out. It took most of the day! And I will forget in a few weeks, but for right now I did it:
I was able to apply the above that @waldauf confirmed: -o nfsvers=4.0.
To do this:
1. Verify the mount is not there. from the terminal I gave "sudo umount /home/jim/NAS_LINK" where NAS_LINK is the directory I used to use to mount to.
2. I offered to mount all but with the new option: "sudo mount -a -o nfsvers=4.0 "
3. It didn't hang the terminal and I could browse to the NAS_LINK directory and see my NAS files and folders!
So, now I had to figure out how to get that option into the fstab.
In reading I found that nsf4 is deprecated but still usable. It should change to only "nfs".
Then, I found that unlike other file systems, nfs has a "helper" it refers to. So you have to put the options into the options area.
I found this meant behind "defaults," and so this works in the fstab for me:
"10.0.0.173:/NAS_BRIDGE /home/jim/NAS_LINK nfs defaults,nfsvers=4.0,_netdev 0 0"
After saving that, I:
1. Go back to terminal and unmount. "sudo umount /home/jim/NAS_LINK"
2. Now, I just tell it to mount all that are in fstab: "sudo mount -a"
Go checked the directory, and my NAS stuff is there.
Hope it works for you!
To do this:
I had this issue last night when I upgraded my client machines to 22.04 LTE (Jammy Jellyfish). I went through a couple hours of debugging last night, and eventually added nfsvers=4.0 to my /etc/fstab entry, and it worked for me. Note that nfsvers=4 will NOT work, as it will still try vers 4.2 and hang.
Could you please explain how you edit the fstab entry? I don't know linux but know how to use putty and run commands. NFS just stopped working after latest upgrade for me.mrobin604 wrote: ↑Tue Jun 07, 2022 1:41 am I had this issue last night when I upgraded my client machines to 22.04 LTE (Jammy Jellyfish). I went through a couple hours of debugging last night, and eventually added nfsvers=4.0 to my /etc/fstab entry, and it worked for me. Note that nfsvers=4 will NOT work, as it will still try vers 4.2 and hang.
- OneCD
The fstab file mentioned is located on the client machine. You don’t need to edit inside the NAS.
Thanks for the reply. I found out why my NFS wasn't working. After updating QTS it seems Advanced Folder Permissions and Windows ACL had been enabled for some reason. All good after disabling them.
