Both are running same version of latest QTS and I was able to sync all my data with HBS via Shared Folders. I recently setup both NFS and Samba (CIFS) mounts in Debian. However when I try to mount either NFS or CIFS, the mount will become inaccessible intermittently with the new QNAP. Not sure what is wrong, it has 4 GB ram and resource utilization is low when it happens.
When using CIFS, this is the error that will show sometimes:
: [82189.618492] CIFS: VFS: \\10.1.1.4 has not responded in 180 seconds. Reconnecting..
kernel: [ 1286.691643] nfs: server 10.1.1.4 not responding, still trying
CIFS
//10.1.1.4/multimedia /mnt/multimedia smb3 sec=ntlmv2,cred=/usr/local/etc/whisper.credentials,uid=1000
10.1.1.4:/multimedia /mnt/multimedia nfs defaults 0 0
This is a virtual VMware server running Debian 11 and it's connected through physical server (Supermicro intel Atom) via 10Gbe (same as the NAS). I don't believe it's a network issue I never see any network drops nor any resource utilization/choke issues (CPU/RAM).
I primarily upgraded to get 10Gbe and have a rackmount so hoping to resolve this without swapping out to another NAS since it works but it's unstable...
