No SSH to Docker container
Locked
mmeewezen
Post by mmeewezen »
Hi guys,
I enabled an ssh server on port 22 and mapped it to the host on 2222 using the advanced config options.
But i cannot connect to it from a client on the same network as the host (=qnap) using
ssh -p 2222 <qnap ip-address>
Port 80 port-mapping works just fine.
Your input would be appreciated.
mmeewezen
Re: No SSH to Docker container
Post by mmeewezen »
Thanks for your reply.
I can access the container with ssh from my qnap terminal.
The qnap seems to be listening on port 2222
tcp        0      0 0.0.0.0:2222            0.0.0.0:*               LISTEN
I rebooted the container and now it does function, but I have not changed it's config, wierd.
oyvindo
Experience counts
Post by oyvindo »
I'm not sure I understand what you're trying to do, but if you're trying to SSH into a container, don't map any ports. Just SSH into your QNAP QTS, and from there, type:
docker exec -t -a <container-ID> bash
OneCD
Post by OneCD »
Viking, I think you're a little-late on this one. It's been 5 years since this was asked. :DD
oyvindo
Experience counts
Post by oyvindo »
OneCD wrote: Wed Apr 21, 2021 3:26 am Viking, I think you're a little-late on this one. It's been 5 years since this was asked. :DD
Ha, ha - you're right! I am embarrassed 😶
Locked
Return to “Container Station”
