Hello I'm new to this forum so hopefully I'm detailing the problem in the correct place. I added a container through Docker which is the Logitech Media Server and configured it fine and it's been working for some weeks now until that is Summer time kicked-in. Now the time on all of my Squeezeboxes is an hour out and I've not been able to find out why. I've restarted the Container and also the NAS to no avail. So any help out there would be great - many thanks in advance!
Paul
Logitech Media Server Container time wrong!
- oyvindo
Re: Logitech Media Server Container time wrong!
You can change the time as follows:
# Change the docker default timezone from UTC to SGT
echo "Asia/Singapore" > /etc/timezone
dpkg-reconfigure tzdata
date
Also check out this post:
http://forum.qnap.com/viewtopic.php?f=354&t=122099
date
- R0GGER
echo "Europe/Amsterdam" > /etc/timezone && dpkg-reconfigure -f noninteractive tzdata
Does somebody knows how to do this?
I cannot get "-v /etc/localtime:/etc/localtime:ro" to work....
gives the following..."/bin/sh: 1: -v: not found"
any help? looks like v command not available...simply need to install? apt-get?
Seriously...anyone able to help here? Have spent a ridiculous number of hours trying to fix this problem!!! Please help before I smash something!!!!
- oyvindo
You seem to insist on getting -v /etc/localtime:/etc/localtime:ro to work!?
I cannot tell you why it doesn't work, but I know that my explanation in my post above does work. Have you tried that one at all?
- OneCD
No, it's because you've only used part of the command-string.vramsay wrote:I cannot get "-v /etc/localtime:/etc/localtime:ro" to work....
Try this one:
docker run -v /etc/localtime:/etc/localtime:ro
Yes, tried your solution as well....couldn't get it to work.
See output below...after running commands the local time is still UTC....
# echo "America/Toronto" > /etc/timezone
# dpkg-reconfigure tzdata
Current default time zone: 'America/Toronto'
Local time is now: Sat Jul 22 01:29:49 UTC 2017.
Universal Time is now: Sat Jul 22 01:29:49 UTC 2017.
Thanks for the help.
SSH Container with putty and login as admin
change time as displayed
restart container!
docker exec -it my-docker bash
exit
docker commit my-docker
