Gitlab - help needed!
I installed the QNAP Gitlab Docker image. No issue occurred. I can access the site and setup my projects. However, after I restarted the container instance, all of my data were gone . Is there any way to save the data to local NAS directory? Thank you very much
Re: Gitlab - help needed!
The issue has been resolved.
- OneCD
1) start containerOneCD wrote:And how did you resolve this issue?
2) ssh into qnap
3) install gitlab-ce from docker hub
docker pull gitlab/gitlab-ce:latest
docker run --detach \
--hostname <your site> \
--publish 10443:443 --publish 10080:80 --publish 10022:22 \
--name gitlab \
--restart always \
--env GITLAB_OMNIBUS_CONFIG="mattermost['log_console_level'] = 'ERROR';" \
--env GITLAB_OMNIBUS_CONFIG="gitlab_shell['log_level'] = 'ERROR';" \
--volume /share/Container/gitlab/config:/etc/gitlab \
--volume /share/Container/gitlab/logs:/var/log/gitlab \
--volume /share/Container/gitlab/data:/var/opt/gitlab \
5) if you've turned on the NAS security (restricted IP access), check your container IP address:
docker network inspect bridge
6) create port forwarding rules for 10080, 10022 and 10443 (if you've configured https) in your router
you may use the container's web interface to stop/restart the gitlab-ce container.
