I tried to install watchtower on Container Station that refuse to start with error
FATA[0000] Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running
Anyone?
Thank you
AleX
Watchtower on Container Station
Re: Watchtower on Container Station
Did you find a solution to this? I'm having the problem now. I don't know how to update radarr and came across watchtower as a solution, but I get this same error.
- Trexx
Here is how to solve it. Different app but does same function as watchtower.
docker run -d --name ouroboros \
-v /var/run/docker.sock:/var/run/docker.sock \
pyouroboros/ouroboros
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Hi Trexx,
Looks like Ouroboros is now unsupported as well, but also has a docker loader in Qnap's listing.
Happy Owner of a TS-H973AX
4 off 4TB WD red spinners,
2 off 2TB WD Red SSD,
Cache 2 off WD 1TB Black U.2. Where there's a will there's a way!
