Error Message = [Container Station] The volume that container-station-data file stored in is abnormal. Go to [Control Panel] > [Storage & Snapshots] to check the volume status.
I have been having some trouble updating apps recently, so I thought that I would look into container station and using docker. However on installing this is the message that I received. I have checked the volume and nothing came back as an issue.
Any suggestions?
Container Station Will Not Start
Re: Container Station Will Not Start
so what is the volume status ?
Is it because my space is too low? I am slowly working through TV eps and movies!
that might be it
Okay thanks for taking the time to respond. I will do some major deleting and see if that helps.
Just in case anyone else is having the same issue.
What I did was uninstall container station, download container station from this post viewtopic.php?t=141355, which did NOT work, but on install with error messages, it asked to update to version 1.9. Once installed, I had to start it and then it continued with no errors.
if it happens again be sure to open a ticket with qnap ..so they can investigate
