I'm running Container Station and created a local Registry. Registered it under Preferences (allowing to trust the self signed certificate).
I pushed an image to this registry from my local machine, which all seems well.
But when I try to create a new container from this image it is no where to be found! When searching for an image I see the extra "tab" in the search results "My registry" but I cannot find any image in there.
I think I'm missing something here, but I have no clue what it is....
Any help would be greatly appreciated!
Regards,
Arno
Finding an image in my local registry
Re: Finding an image in my local registry
Do you found a solution for this? I have exactly the same issue. My registry is also running my nas using the official docker regsitry container/app.
- oyvindo
Why do need a separate registry?
Just use export/import or simply use the Image registry which is default used by CS.
Why do need a nas?
Just use an usb disk and simply attach it where you need your data.
I have the same problem.
I have installed Gitlab and a private registry. With CI / CD I can build and push my images to the registry, but I cannot find the images sent to the registry from the Container Station search.
Also, still from Container Station, I am not able to create instances with my images using the application creation with the use of the YAML configuration; when Container Station tries to download the image it fails.
Oddly, if I go to the image management section, I can successfully pull images from my private registry; however I still can't use the image with the YAML configuration.
I wanted to try using Docker from the CLI. However, it is a pity that we cannot use the interface
PS. I can provide screenshots and YAML configuration, if it can help solve this nasty problem.
Sasori I’m on the the same situation as you were in April, did you sorted out?
I’m replying to myself and might help someone in the future.
I found a workaround to start stop this from container station but I had to SSH to NAS then head to /share/Container/container-station-data/application/<your app>
And run a docker-compose up one time from the shell. After that worked like a charm.
Thanks for your self reply. I am facing the same issue.
running docker compose on the command line works, however the image from the private registry does not get pulled within the UI.
The error indicates that the login does not work well for pulling images. The credentials are set up properly in the preferences
