I'd like to use docker-compose on the ssh.
My problem is that even if I only use one container, it makes an app out of it.
And so they are all in a certain dependency.
They cannot be started or restarted individually.
I would like to use single containers, but with docker-compose.
Anyone have an idea? or what am I doing wrong?
In the previous version that was still possible.
greets
Thomas
docker-compose ssh, how?
- howarmat
Re: docker-compose ssh, how?
You would need separate docker compose files for each container you want to use. I made a separate shared directory just for all docker stuff, then a folder for each container with a docker-compose file for each. I also made any volumes required for that container point to this folder so it would be static and outside of the container station. You can then ssh and run the commands to rebuild at anytime with updated image
Hope this helps a little.
Sample file
Sample file
version: '3'
services:
hydra2:
container_name: Hydra2
image: linuxserver/hydra2
restart: unless-stopped
environment:
- TZ=America/Indianapolis
- PUID=1000
- PGID=1000
volumes:
- /share/DockApps/NZBHydra:/config
- /share/Download:/downloads
ports:
- 5076:5076
hello
i´ve tried with only one Container in my docker-compose file, and it appears also as an APP. What version of CS do you use? 2.0.117 ?
greets
greets
- howarmat
yes the newest update the other day
i have tried your docker-compose.yml
but i also get an APP:Docker and can not stop or remove the Container inside the CS GUI.
i get an error message.
I must stop it at the command line.
A view weeks ago i tried this an it works so. But since the update not.
i now have gone back to 1.9.3590 and for me now all is ok.
- musicfreak
for that start stop thing i also had the same problem but Logicwar had a sollution.
they changed the directory where the dockers are now. So it need to be there. I still have problems with some files after this.
Logicwar wrote: ↑Mon Apr 22, 2019 1:06 am Had the same problem.
You can fix it by creating a folder with the name of your application in the following folder:
/share/CACHEDEV1_DATA/Container/container-station-data/application/
In that directory you should have the following two files
- docker-compose.yml : your application yml file
- qnap.json : should contain the following texte with the application name replaced by your appplication name : {"services": ["application name"], "httpPort": 0, "name": "application name", "createFrom": "custom"}
You can try to create a new application from the gui and see what get's created in the folder.
What drives me crazy now, is that all containers starts after rebooting the QNAP. Can't find out how to disable this. Already tried to add in the docker-compose.yml file [restart: "no"] with no success.
- howarmat
So I actually just created the folders and added the docker-compose file and not I can start and stop without issue. No qnap.json needed that I can tell
