While we can decide to enable or not an autostart for a single container, I cannot figure out how to do it for an application.
All applications are starting after a reboot. Editing the configuation (Docker Compose) via the GUI and adding [ restart: "no" ] is not helping (nor setting it at creagion). I really need to select which applications must restart after reboot and which don't.
Any ideas?
Disabling autostart for applications
Re: Disabling autostart for applications
As a temporary fix for the unwanted auto start of all applications, one can:
1. Create a folder called '_stopped" in the "/share/CACHEDEV1_DATA/Container/container-station-data/application/" directory
2. Move the application folders which should NOT be started (they will be become greyed out in the GUI)
To start an application, move the application folder back to the main directory.
Very ugly, but until support gives a solution….
Hey did you end up finding a better solution?
- oyvindo
I think that if you manually stop the Application before reboot, it will not autostart during reboot.
