Login user and password for Ubuntu 18.04 in Linux Station
I just install Ubuntu 18.04 in Linux Station. It need the user and password to login. But I try everything I can. root, ubuntu, admin and my own qnap admin password. anyone know the login information. Thanks!
Re: Login user and password for Ubuntu 18.04 in Linux Station
did you disable the system "admin" user? I found it won't let you log in or show the admin user icon at the ubuntu login screen unless that account is enabled when you set it up. It uses the same password as the system "admin" user.
So you seriously have to re-enable the 'admin' user account - which is a huge target for hacking - to use Linux-Station? That's ... ummm ... let's say 'less than ideal'.
- OneCD
