I have two nics on my TS-453Be. I have setup a VLAN (VLAN 44) on adapter 2 and I'm able to create a Virtual Switch which connects to vlan 44 (I call it Virtual Switch 2-V44). As you can see on the diagram it's working fine and it gets an IP. However regardless of anything that I do, I am unable to connect one of my Containers (openhab) to that v44 switch. See attachment. What I want is to connect the red line.
I have tried changing the settings in the configuration of that virtual switch (see attachment)... I go through it selecting the VLAN 44 switch and the container that I want to have connected to it, but nothing changes and it remains connected to the one it is currently connected to.
It's frustrating. Am I doing something wrong or is this the same bug that others are talking about here?
QNAP, any fix for this?
Cannot connect a Container Station to VLAN Virtual Switch
Re: Cannot connect a Container Station to VLAN Virtual Switch
One more thing... In Container Station, there's no option to select the VLAN Virtual Switch... it doesn't show in the list. (See attachment)
I have this working. on QTS 4.4.3
My setup:
One of my QNAP adapters is named Trunk. It is plugged into a switch port that has no default VLAN ID, so all traffic must be tagged. I added a few VLANs to Trunk In Container Station, I chose Bridge mode networking and Trunk as the interface. As you say, the Trunk (VLAN: 1) is not a choice here. I saved the container settings, then went over to Network & Virtual Switches I found the switch that was connected to my container. In the image below the container's adapter is called unifi_Virtual Adapter 1. I then edited that Virtual Switch's settings. From this settings screen, I can select Trunk (VLAN: 1). I also renamed the virtual switch to Container VLAN 1 so I can identify it later. When I started my container, it got a DHCP address in the VLAN 1 subnet and I was able to talk to it on that IP address.
My setup:
UPDATE: The method I describe above does not survive a reboot of the NAS. On reboot, the auto-started container ends up connected to an entirely new Virtual Switch which is wired to the main interface, not a virtual interface.
I swear I tested reboots before and thought it worked. I guess not.
Thanks for your reply @kbyrd. I had already tried the method you described and couldn't even get to work prior to a reboot, let alone after.
Can anyone describe a way to do this? Perhaps by editing some setup / config file in docker?
Sorry to bump an old thread, but has anyone found a solution to this?
- Toxic17
obviously not. best to raise a ticket with QNAP.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
I am using 5.0.0.1828 and the problem is still alive.
Is there any progress about it?
