Does anyone know how to get the real CPU and memory usage of a container? When it first appeared that memory was maxing, I passed passed the "-e CRASHPLAN_SRV_MAX_MEM=40960M" in creating the container as I wanted to give it nearly everything on memory to see where it topped out. But I cannot tell what it's actually doing. Here is what I see for Crashplan pro as an example during a backup:
Container station data 1:
Container station data 2:
A pure "docker stats" in the CLI on the core NAS:
And finally, and "top" command from inside the docker shell:
Container settings:
What is real? It looks to me the 21% CPU is real as I also did a TOP on the NAS CLI, and it matched the container TOP cpu usage. Resource panel on the NAS shows memory is 89% free which seems real.
So it seems the "RAM at 91%" in the Crashplan container station view is total BS? Or is there some limit on a container I don't know about and that's why it shows 91%?
Q
True memory and CPU usage not matching docker stats
- Qmann
- Easy as a breeze
Model: TVS-872XT 64GB (Crucial 64GB Kit CT2K32G4SFD8266)
2 x 1TB XPG 1TB NVMe (ASX8200PNP-1TT-C) [RAID-1]
5 x 16TB EXOS [RAID-5]
Borg Backup running to an offisite pi, AND to the local TS-569L
Model: TS-569L Borg server for backups
6 x 8TB Ironwolf [RAID-5]
Qotom-Q355G4 Fanless Mini Micro PC running pSense in front of everything
haproxy for anything inside the LAN
- Qmann
- Easy as a breeze
Re: True memory and CPU usage not matching docker stats
Any takers?
I have a somewhat similar question and just opened a new topic on it. My Container Station Overview is showing 74% RAM usage, but the system is only showing 13%. There are 8 LXC containers running, but seven of them show 0% RAM usage and the last one shows 1%. In other words, they aren't using much. I'm not sure why there's a difference between what Container Station is showing and what the system is showing.
Model: TS-h1277XU-RP
FW: h4.5.1.1491
FW: h4.5.1.1491
- Qmann
- Easy as a breeze
I haven't been able to figure it out and assume that container station is just plain wrong.
I've also noticed that the containers I have on "host" networking always show a consistent volume of network traffic and exactly the same even though they're all doing nothing. It's obvious the data is coming from higher up the chain I guess.
Might be that the Container uses dynamic memory, and can expand from 0 to 8GB (in my case with an memory-upgraded a TS-431P2), but as long as it only requires let's say 700 MB memory at the moment, then is reserves only 1GB for the Conatiner itself, and then the 70% of 1GB is what we can see in Container Station, while in Resource Explorer it is much less?
- ve7tcc
I have the same problem. I removed all containers, and it says 81%
I stopped QuMaggie, Qsirch, QNAP AI Core, and still 81%
Resource monitor shows only 28% usage.
Awaiting a call from QNAP support.
Model: TS-h973AX
FW: h4.5.4.1800
FW: h4.5.4.1800
Hello. Did you get an answer from QNAP Support?
TS-H886
