Clang on armhf
grigorye
Clang on armhf
Post by grigorye »
Hi folks, I'm trying to experiment with build some stuff in Container Station on TS-431P3 (that is armhf/arm32v7).
While everything "works" so far, I got a problem with Clang. It basically segfaults on launch like below:
Ubuntu 18.04.5 LTS ubuntu-bionic-armhf pts/1
ubuntu-bionic-armhf login: ubuntu (automatic login)
Last login: Sun Apr  4 08:48:49 UTC 2021 on pts/0
Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.2.8 armv7l)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
ubuntu@ubuntu-bionic-armhf:~$ uname -a
Linux ubuntu-bionic-armhf 4.2.8 #2 SMP Tue Mar 2 10:59:21 CST 2021 armv7l armv7l armv7l GNU/Linux
ubuntu@ubuntu-bionic-armhf:~$ clang
Segmentation fault
I tried several (stock) containers like LXC ubuntu/bionic, debian/buster, Docker ubuntu/bionic etc, as well as *different* versions of clang. All the combinations crash like above.
For the reference, GCC etc works without a problem.
So, I wonder if there's something wrong on the host side of the system. I do have some Entware stuff installed there but it's pretty minimal/I'm not sure it causes this thing (no clang or something there, just in case). Other than that, I can't recall anything non-standard on the host side.
Any clues/hints?
Regards,
Grigorii
grigorye
Re: Clang on armhf
Post by grigorye »
Just in case, luckily, pre-built binaries for Clang hosted on LLVM releases page seem to work correctly... So, I wonder whether this problem is specific to Debian/Ubuntu package or something... Still looking for any clues.
Return to “Container Station”
