i have PiHole running on my NAS as a container. Works really nice so far. As Containers are not done for updates it will be deleting the old one and installing the new one.
My problem is that i will loose all my config that i´ve done to Pihole. I have read lots of articles but did not find any answer specific for QNAP.
Is there a way to save my current config?
If not, guess i have to fill out this stuff (image attached) Can someone explain what do i need to fill out here so next time i want to do an update i won´t loose my config?
thanks in advance!
Container PiHole configuration files special QNAP
Model: TS-459 Pro+ (4x 2TB -> RAID 5)
Model: TS-251 (2x 3TB -> RAID 0)
Model: TS-853a (8x 4TB -> RAID 6)
- uwe_k
Re: Container PiHole configuration files special QNAP
You can use PiHole Teleporter (in Settings) to export/import all your settings.
Uwe
Uwe
- oyvindo
I'm using an LXC container and all I ever do to update is to enter the container and type "pihole -up"
I just removed my raspberry pi device from my network and instead installed pi-hole in a container.
I had an unexpected shutdown and Container Station was stuck.
When I uninstalled Container Station and I expected to have to reinstall pi-hole, but when I reinstalled Container Station it asked me if I wanted to use the same pi-hole folder. I said yes, and it picked right up, pi-hole installation, password the same.
Workstation DAS/NAS: TVS-872XT i5 16GB QuTS Hero 5.x + 2x NB 12-P fans
2x1TB Samsung 970 EVO plus RAID1 w/EK WB M.2 heatsinks
8x20TB Seagate Exos X22 RAID6 112TB Thin volume
1x20Gbe Qnap Thunderbolt 3 card, 1x40Gbe Mellanox DAS network connection, 10Gbe local virtual switch
Backup NAS: TVS-872XT i5 16GB QTS 5.x + 2x NB 12-P fans
8x10TB WD Gold RAID6 54TB Thick volume w/snapshots
1x40Gbe Qnap Thunderbolt 3 card, 1x40Gbe + SFP+/RJ45 for local 10gbe virtual switch
LAN switch 10Gbe(2)/1Gbe(8) NETGEAR Nighthawk SX10 (GS810EMX)
