I need some help please to gain access to my TS-831X which can longer be found with Qfinder or accessed via the web GUI or SSH.
Background
- I installed Container Station to test out the Ubuntu LXC container, the one that can be installed from the Create menu in Container Station.
- The NAS firmware and Container Station ware updated prior to me installing the Ubuntu LXC container.
- I selected the following options for the Ubuntu LXC Container: Bridged Network, Static IP, 20% CPU, 2GB RAM.
- During the installation the NAS became unresponsive and I was unable to load any new windows through the web GUI.
- After about an hour I performed an IP scan and the NAS and static IP chosen for the Container were visible.
- I then restarted the NAS.
- It boots up normally, all the lights appear normal and if I scan the IP addresses on my network the NAS and Container's IP addresses are active (Qfinder can't find the NAS though) but can't be pinged.
- The Manufacturer of the Container reports as "Xensource, Inc" in the IP Scan software.
- When I attempt to navigate to the web GUI I get a connection time out error, no luck with SSH either.
- I have removed all the hard drives and started the NAS, it was discoverable through Qfinder and I could access the web GUI, which displayed the setup page, and I could also access it via SSH.
- On placing the hard drives back and restarting the NAS I got the same problem.
Your help is appreciated!
Thank you
Hulahoop
